3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How do I ground myself from static?
I'm thinking about building my own custom PC but I need to ground myself to protect it from ESD. I can't buy a anti-static wrist strap because I don't know anywhere that sells them and I don't want to purchase it online. I've heard that if you're power supply is plugged in and off that you can touch the edge of the case (the power supply is already mounted). Is this true? Please reply. Thanks.
Feb 16, 2009. 12:28 AMUziMonkey says:
The chassis of the computer and power supply are connected to the ground pin. So if the machine is plugged in, you can indeed touch the chassis to discharge any static electricity. This is less of a problem than you think. I've been working on machines for a long while now, and I've never shocked anything (at least nothing I've noticed). I usually touch the screw on a light switch before working, and at intervals while working. Unless it's really dry and you're wearing a sweater or something, you probably won't have any problems just doing it this way.
Feb 16, 2009. 10:39 PMUziMonkey says:
Of course. Whether it's on or off, the chassis is still grounded to the third pin of the wall socket. Assuming that itself is grounded (some older houses don't have grounded outlets), you should be safe.
Feb 17, 2009. 4:48 PMNachoMahma says:
. You can make your own anti-static strap with an approx 1MegOhm resistor. Google is your friend.
Feb 16, 2009. 4:40 AMl96470fps says:
you said that you dont know where to get an antistatic wrist strap, if your in the uk try maplins or pc world, and look on google earth for your nearest store.
Feb 15, 2009. 10:45 PMChrysN says:
Here is a static discharge thing you can make yourself. There is also an article about how to avoid static when you are working on your PC, which mentions using the case (but read article first). You can probably get a wrist-strap at Radioshack or a store which sells PC components.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
