How to create a basic save/open file dialog in Visual C#?
I am creating a simple Sticky Notes application that will open/read/save text files (in a *.sticky) extention. I was able to code the entire application, except for the save, save as, and open commands. Does anyone know how to do this?
using System.IO;
// The button callback for the "Save Notes" button
private void OnSaveFileButtonClicked(object sender, System.EventArgs e)
// Configure savefile dlg with your stuff
SaveFileDialog saveFileDlg = SaveFileDialog();
// Convenient if you already have a application directory to store notes in
saveFileDlg.InitialDirectory = "%USERPROFILE%\\Documents";
saveFileDlg.Filter = "Sticky Note File (*.sticky)|*.sticky|All Files (*.*)|*.*";
// it's nice to use the folder that the user has been using if any
saveFileDlg.RestoreDirectory = true;
// present the dialog to the user
if (saveFileDlg.ShowDialog() == DialogResult.OK && saveFileDlg.FileName != "")
// now the user has dismissed the dialog so check for their choices
using (FileStream ostr = saveFileDlg.OpenFile())
if (ostr != null)
ostr.Write(noteTextArea.Text, 0, noteTextArea.TextLength);
// callback for the "Open Sticky Notes" button
// it's similar to above so no big surprises here
private void OnOpenStickyNote(object sender, System.EventArgs e)
Stream ostr = null;
OpenFileDialog openFileDlg = new OpenFileDialog();
// again, be nice and setup the dialog for your user
openFileDlg.InitialDirectory = "%USERPROFILE%";
openFileDlg.Filter = "Sticky Notes (*.sticky)|*.sticky|All Files (*.*)|*.*";
openFileDlg.RestoreDirectory = true;
if (openFileDlg.ShowDialog() == DialogResult.OK)
if ((ostr = openFileDlg.OpenFile()) != null)
using(ostr)
// now open the file, parse it, or do whatever you need to here
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
using System.IO; // The button callback for the "Save Notes" button private void OnSaveFileButtonClicked(object sender, System.EventArgs e) { // Configure savefile dlg with your stuff SaveFileDialog saveFileDlg = SaveFileDialog(); // Convenient if you already have a application directory to store notes in saveFileDlg.InitialDirectory = "%USERPROFILE%\\Documents"; saveFileDlg.Filter = "Sticky Note File (*.sticky)|*.sticky|All Files (*.*)|*.*"; // it's nice to use the folder that the user has been using if any saveFileDlg.RestoreDirectory = true; // present the dialog to the user if (saveFileDlg.ShowDialog() == DialogResult.OK && saveFileDlg.FileName != "") { // now the user has dismissed the dialog so check for their choices using (FileStream ostr = saveFileDlg.OpenFile()) if (ostr != null) { ostr.Write(noteTextArea.Text, 0, noteTextArea.TextLength); } } } // callback for the "Open Sticky Notes" button // it's similar to above so no big surprises here private void OnOpenStickyNote(object sender, System.EventArgs e) { Stream ostr = null; OpenFileDialog openFileDlg = new OpenFileDialog(); // again, be nice and setup the dialog for your user openFileDlg.InitialDirectory = "%USERPROFILE%"; openFileDlg.Filter = "Sticky Notes (*.sticky)|*.sticky|All Files (*.*)|*.*"; openFileDlg.RestoreDirectory = true; if (openFileDlg.ShowDialog() == DialogResult.OK) { if ((ostr = openFileDlg.OpenFile()) != null) { using(ostr) { // now open the file, parse it, or do whatever you need to here } } } }That should be about it. Hope this helps! -gianit might be able to be simplified
private void openToolStripMenuItem_Click(object sender, EventArgs e)
DialogResult result = new DialogResult();
if (kiemtrasave == 2)
result = MessageBox.Show("Click Yes to Save or Click No to Exit", "Warning", MessageBoxButtons.YesNoCancel, MessageBoxIcon.Warning);
if (result == DialogResult.No)
openFileDialog1.FileName = "";
if (openFileDialog1.ShowDialog() == DialogResult.OK)
richTextBox1.LoadFile(openFileDialog1.FileName);
this.Text = cap + ": " + openFileDialog1.FileName;
else if(result == DialogResult.Yes)
if (path != "")
saveFileDialog1.FileName = path;
richTextBox1.SaveFile(saveFileDialog1.FileName);
kiemtrasave = 0;
this.Text = cap + ": " + saveFileDialog1.FileName;
path = openFileDialog1.FileName;
kiemtrasave = 0;
else
if (saveFileDialog1.ShowDialog() == DialogResult.OK)
kiemtrasave = 0;
kiemtrasave = 0;
else
kiemtrasave = 0;
private void newToolStripMenuItem_Click(object sender, EventArgs e)
result = MessageBox.Show("Click Yes to Save or Click No to Create a New text", "Warning", MessageBoxButtons.YesNoCancel, MessageBoxIcon.Warning);
if (result== DialogResult.No)
richTextBox1.Clear();
this.Text = cap;
kiemtrasave = 0;
if (path != "")
this.Text = cap;
kiemtrasave = 0;
else
kiemtrasave = 0;
path = saveFileDialog1.FileName;
else
path = "";
this.Text = cap;
kiemtrasave = 0;
private void saveToolStripMenuItem_Click(object sender, EventArgs e)
if (path != "")
kiemtrasave = 0;
else
kiemtrasave = 0;
private void saveAsToolStripMenuItem_Click(object sender, EventArgs e)
kiemtrasave = 0;
this application for my examination
note: kiemtrasave is variable that you check the richtextbox saved or not
0 is saved.
