How can I let Arduino GSM shield respond to specific numbers?
I am working on a project where i send 1 to my GSM Shield to switch on the LED connected to pin 13 and off by sending 0, but i would like to modify the code in order for the GSM Shield to respond only to the number specified. Here is my code, in my case I used an example phone number ...
// include the GSM library
#include <GSM.h>
// PIN Number for the SIM
#define PINNUMBER ""
// initialize the library instances
GSM gsmAccess;
GSM_SMS sms;
// Array to hold the number a SMS is retreived from
char senderNumber[20];
char adminNumber[20]="+123456789234";
void setup()
  // initialize digital pin 13 as an output.
  pinMode(13, OUTPUT);
  // initialize serial communications and wait for port to open:
  Serial.begin(9600);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.println("SMS Messages Receiver");
  // connection state
  boolean notConnected = true;
  // Start GSM connection
  while (notConnected)
    if (gsmAccess.begin(PINNUMBER) == GSM_READY)
      notConnected = false;
    else
      Serial.println("Not connected");
      delay(1000);
  Serial.println("GSM initialized");
  Serial.println("Waiting for messages");
void loop()
  char c;
  sms.remoteNumber(senderNumber, 20);
  sms.remoteNumber(adminNumber, 20);
    // If there are any SMSs available()
  if (sms.available())
    Serial.println("Message received from:");
     // Get remote number
    Serial.println(senderNumber);
       // Any number besides admin number will not change the state of the pin
    while(adminNumber == senderNumber){
        // Any messages starting with 1 will set pin 13 to HIGH
if (sms.peek() == '1'){
      digitalWrite(13, HIGH);
     sms.flush();
        // Any messages starting with 0 will set pin 13 to LOW
else if(sms.peek() == '0'){
      digitalWrite(13, LOW);
        sms.flush()
    // Read message bytes and print them
    while (c = sms.read())
      Serial.print(c);
    Serial.println("\nEND OF MESSAGE");
    // Delete message from modem memory
    sms.flush();
    Serial.println("MESSAGE DELETED");
  delay(1000);
What do YOU mean by "respond only to the number specified"
The way its written, it should respond only to an SMS from the "correct" number.
Mechatron147 (author)  steveastrouk1 year ago
That's what I want but its not working. By number specified I mean the number in the array "adminNumber"
So its responding to every number, or not even the right number ?
It skips the while loop where i compared the senderNumber to adminNumber... It displays the message content and the senderNumber but the LED doesn't switch on
Your string contains extra characters. Search for the adminnumber as a string within the sendernumber, not an == statement
How exactly can I do that? Can you give me a sample code?
Mechatron147 (author) 1 year ago
Sorry I didn't get what you mean. Can you clarify?
There are two IF statements defining what happens when a number is received - change them to what you need.
Sorry but can't make it any clearer.
I wonder if its the OPs code, or if its been, ahem, borrowed.
Actually I used the Send SMS example from the IDE and modified it
So why don't you change it, it is just two IF statements...
