I need a help on fixing the OBD II codes P0452 and P0410 for a 2001 s10 4wd blazer 4 door?
I was told that the vacuum lines could have a problem with this if they are cracked or there is a leak
Nov 21, 2011. 9:21 AMred9er says:
to find a vacuum leak you can also use propane or simular gas. let it out where u think the leak is and it will suck the gas into the engine if there is a leak. the idle will change. i know this trick works for leaking carberators, so i assume it will work for other vacuum problems.
Jul 16, 2011. 3:35 AMJack A Lopez says:
You know, you can look these codes up yourself.  It looks like the ones you mention are related to emission control.  Here:
http://www.obd-codes.com/trouble_codes/
http://www.obd-codes.com/p0410
http://www.obd-codes.com/p0453
2000 S10 P0452 and P0453 Codes - forum topic
http://www.obd-codes.com/forums/viewtopic.php?f=1&t=1531
Jul 15, 2011. 11:57 PMlemonie says:
It would help if you hadn't assumed that someone knew exactly what you were talking about. I didn't know what any of these things were - you made me Google them.... and that's probably your best bet without taking it to a dealer.
I found nothing definitive but you might get a better idea, e.g. http://autoforums.carjunky.com/Automotive_Repair_C1/Engine_Fault_Codes_F29/1999_chevy_s-10_blazer_check_engine_P0410_P49829/
L
Jul 15, 2011. 9:45 PMorksecurity says:
If the problem is leaking vacuum lines -- either go around the engine with a piece of tubing as a stethoscope listening for the hiss of air being sucked in, or put a vacuum gauge on the system and try clamping various vacuum lines (or disconnecting them and plugging their connection) until you find the one that makes the vacuum increase.
Once you've found the leak, replace whatever is leaking.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
