3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Looking to replace LEDs with solenoid driven indicators.
I'd really like to replace some LED indicators with physical on/off indicators, like they used on old NASA spacecraft. To see what I'm talking about take a look at this console from Apollo 14 at the little windows above the switches at the center left. The top row is all "barber poll" the bottom row open.
My initial thought is that I could possibly replace the LEDs with a solenoid that would shove an "on" indicator into a little window when powered, and retract it when powered down.
The problem: I know next to nothing about solenoids and don't know if this is feasible. They'd need at least 1/4" throw and to run at low power if they're going to simply be a drop-in replacement for LEDs. What kind of solenoid am I looking for and does it even exist?
Jun 16, 2009. 9:01 PMorksecurity says:
No solenoid will ever be as low-power as an LED.A better bet might be to run the LED output into a transistor or mini-relay which would act as an amplifier, switching power from a separate source to drive the solenoid. I'd suggest hitting your library for a hobbyist-electronics book with a project that shows how to control a relay from a digital logic chip's output. Then either replace the relay coil with the solenoid, or use the relay to control the solenoid. Remember to allow for back-EMF as the solenoid's power is switched off; you may want a shunting diode to protect the electronics from that.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
