loading
Using an electric shock to trigger an arduino. (doorknob variety)
I was thinking a transistor, how does one make ~20000v at 5mA useful. Do I use a capacitor or a coil of some type? Do I NEED an amp? Will it be jittery? I was even looking at those alfoil leaf static detectors and imagining some sort of field detecting reed switch.. ?
Think frankenstiens lab: lightning=reaction :)
Ya ! if a situation where this can be used, is explained, you can have more appropriate answers.
oliverkellow (author)  iknowvations5 years ago
Note: only tried with a cheap multimeter so far, i might make my first instructable if my circuit board does not blow up :O
After consulting my professor, (who hates all HiVoltage because it is a harbringer of elecronic component death), we found that placing an insulated wire inside an earthed metal tube and zapping the outside tube produces a spike signal in the inside wire (like an antenna sensing the activity nextdoor..).
--------------------------| __________________GND
~~~~~~~~~~~~~~o-----------------|
--------------------------| |___VVV-------VVV------ ANALOG PIN arduino
...............................|_____________________________ GND
Sorry: first ever ASCII circuit :P
~~~~insulated wire (SHOULD NEVER BE ZAPPED)
Conductive tube, must be earthed
vvvvvvv high resistance resistors (2x 1Mohm in my case)
iceng5 years ago
Are you trying to build a device to kill someone when they touch the doorknob ?
Or are you wanting to detect a person is touching the doorknob ?
A
