Whats the best way to clean a Magic Bullet Power Base?
The Milkshake leaked out of the bottom of the container and went through the power base before I noticed it leaking out of the bottom of the power base. Is there any way to clean the inside of the power base?
Or can I just keep using it with out worry of it exploding or something?
Vyger6 years ago
You have to get some of my special Magic Bullet Power Base cleaner solution.
If it has a bottom plate on it that can be removed by taking out a few screws then remove it. Then do what all the safety stickers tell you not to do and wash it in the sink and get it clean. (please unplug unit before washing). Then the most important thing to do is get it dry. Use a hair dryer and get it as dry as possible. Pay attention to anyplace that the water might have gotten into. After you think its completely dry then leave it sit for a couple of days so it can really get dry. After that put the bottom back on and try not to get stuff in it again.
MaryannJ2 years ago
I know your not suppose to immerse the entire bottom in water BUT every month I get very hot tap water and squirt it into the bottom motor part. I then shake the water around in there a few times and repeat at least 6-7 times. It is amazing how much gunk comes out. I let it sit for 3-4 days to dry out. I have been doing this for about 7 months and my bullet still works great and has no puke smell coming from the base
caarntedd6 years ago
You can buy a spray can of solvent used to clean the internals of electrical/electronic equipment (known as contact cleaner around here). Spray it on and scrub with a small paintbrush, it evaporates almost instantly and leaves the surface dry and clean. Should be available at electrical/electronic suppliers, or a decent hardware store.
