Where to start prototyping with straingauges?
Can anyone recommend a reasonably-priced prototyping kit for straingauges or something similar, and/or a good document on how to actually design around these beasts? What I'm trying to build is essentially a box with a handle on each end, which can measure the force applied inward or outward on those ends. Measurement range would probably about +/- 40 pounds, though I'd be happier if it could tolerate (but not necessarily measure) higher forces just in case someone does something stupid. The measurement doesn't have to be on a smooth curve but does need to be continuous and repeatable so I can calibrate it reasonably accurately. If you think of it as a kind of game controller, where you're squeezing it together or pulling it apart to varying degrees to make the game respond, that's fairly close to what I need. Doesn't necessarily have to be straingauge, but needs to be something with essentially that behavior -- I really want to measure the pressure/tension applied with imperceptable motion (for fast response). And yes, I do need both directions. Unfortunately all the documentation I've found on straingauges talks about the electronic aspects. and says very little about the practical mechanical aspects of working with them. And I haven't yet seen anything resembling a reasonably priced experimenter's/prototyping kit from any of the manufacturers. Yeah, I suppose I could cannibalize an electronic scale for the first prototype... but I'd still like to learn the proper approach and find an experimenter-friendly source of parts.
Sep 4, 2009. 10:11 PMseandogue says:
(removed by author or community request)
Sep 5, 2009. 9:45 PMseandogue says:
Sep 6, 2009. 8:01 AMseandogue says:
Sep 6, 2009. 3:25 PMseandogue says:
Sep 4, 2009. 10:19 PMseandogue says:
Sep 5, 2009. 9:48 PMseandogue says:
Sep 6, 2009. 3:13 PMsteveastrouk says:
SPotted resistive strain gauges on a UK site (rapid electronics) which work out at around 7 USD each
Sep 6, 2009. 1:52 AMsteveastrouk says:
Are you hung up on resistance straingauges ?
Why not use piezo based gauges instead, or simple conductive foam pressure sensors, suitably arranged or Honeywell force sensors
http://www.sensortechnics.com/index.php?fid=300&fpar=YToxOntzOjQ6InBjaWQiO3M6MzoiMjkyIjt9&isSSL=0&aps=0&blub=11b8e04d254e080ccd94ef5fcd1b3938
How stiff do you want this thing to be ? If you can allow some compliance while the force is applied, you have even optical methods that could measure force -a pair of fibres perhaps, with the coupling allowed to flex.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
