Why won't people use dpdt switches in their coilguns?
But i will start my coil-gunning with switches.
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
When your switch closes to send CAP bank to the coil...
Even the silver contacts will weld the switch always closed for ever.
Why ?
The initial current surge will be Hundreds of amps heating the contact points to the melting point silver causing the contacts to weld each other into a single mass of metal...
The way to avoid welding contact is to use a fast power SCR,
see the pic.
A
You're using the correct drawings for the SCR, resistors, triac, and for the diode, why wouldn't you use them for the switch(?) and for the batteries?
And that moc3023 is a microcontroller?
also, ICENG?
Sorry if this is offensive.
- That is a foot-switch.
- A switch that is activated be a foot pressure.
- What is correct ?
- If you can tell its a battery and a switch, I have succeeded :-)
- What voltage am I suggesting ?
- MOC3023 is an optical isolating 6pin IC ( Integrated Circuit )
- MOC3023 uses LED light to in effect close a switch from pin4 to pin6 when the foot presses the red button down.
- I used to design Integrated Circuits as an engineer ( IC eng )
- I'm smiling and Not at all offended..
Abut my coilgun is going to be small-scale.
And the main reason i'm asking this question as i see lots of coilgun instructables with separate trigger and capacitor loading switches.
and im wondering that if it can be done with one single switch.
which has like 500 µf at 450 volts.
And i do know that switches weld, fixed one switch today that had contacts welded. it was pointless because we had a new switch coming through the mail.
As soon as i have money/ordering huge stack of parts, i'm buying the SCR.
You saying I shouldn't have stopped The Ideanator from trying to wire a 240V relay with uninsulated copper wire? It's okay though, he was going to isolate it by holding it away from the metal frame with an insulated pair of pliers.
OH! And follow your instinct but follow your sense of smell closer. If you can smell it, you can stop it.
However, if you're dealing with something relatively expensive, and it was purchased on somebody else's dime, then you really don't have the right to mess around with it when there are known and researchable precautions you can take.
And, btw, I agree with you philosophically, so don't think Im giving you crap, its a good message your trying to put out there.
