how do i put a stem back on my pumpkin?
 my pumpkin's stem fell off but i need it on in order to do my carving in it i already tried hot glue
jeff-o8 years ago
Why do you need the stem to carve a pumpkin?  So you can take the lid off?  Just cut a finger hole in the top.  You need a hole in the lid anyway so the candle has a vent.
annoyingfeatures (author)  jeff-o8 years ago
 no im using to stem as something in my carving, its gonna be like a dead tree
In that case, get a thin piece of wood about 2-3" in diameter.  Drill two holes in it, with diameters smaller than the head of a deck screw.  Hold the wood in place under where the stem should go, and hold the stem where you want it.  Drive two 3" deck screws through the holes in the wood, through the pumpkin, and into the stem.
knex_mepalm8 years ago
Get another one!
Super Glue is amazing
You could try driving the sharp end of some sewing needles into the base of the stem. Pumpkins are tough--mebbe you'll need a hammer. Then, push the stem into the pumpkin. You might need to make pilot holes with another needle or pin first.
Maybe you could use toothpicks or thumb tacks.  That way you can stick it back on if it falls off again.
acidbass8 years ago
super glue green electrical tape ummm nails all of those shoul work
lemonie8 years ago
You might be able to spike together it with sharpened matchsticks / cocktail sticks?
L
Burf8 years ago
Use a toggle bolt. Cut the head off the screw and thread it up into the stem, bore a small hole in the pumpkin just large enough for the toggle to pass through where the stem was attached. Gently tighten the screw into the toggle.
That should do it with a little care and patience.
Burf Burf8 years ago
One other thought, you can use a corkscrew to lift the top for carving if you're not specifically concerned about reattaching the stem.
