3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
how to make glass prism?
Feb 4, 2011. 1:22 PMorksecurity says:
Obtain/cast a clear block of glass, preferably of high refractive index, preferably already molded into a suitable shape. Polish/grind//cut to shape if not already suitably shaped. Grind/polish surfaces to optical quality.
Feb 4, 2011. 1:34 PMsteveastrouk says:
Ever tried it, for real ?
Feb 5, 2011. 2:14 AMKiteman says:
(I think he was being sarcastic)
Feb 5, 2011. 8:30 PMorksecurity says:
Not entirely sarcastic -- just pointing out that doing it right is a nontrivial project, and it's cheaper and easier to buy unless you are have special needs or are particularly attached to doing it yourself.
Actually, you can make a _small_ prism by grinding/polishing a suitable bevel into the edge of a sheet of glass. My bathroom mirror has some decorative triangular grooves ground into it, and when the light hits them right they do disperse colors.
Acrylic/plexy is, of course, easier to work than glass. I don't think you can fire-polish plastic, though.
Feb 4, 2011. 1:23 PMsteveastrouk says:
A real one, or a toy ? A toy one I'd make in plexiglass.
Feb 4, 2011. 1:38 PMorksecurity says:
Or as three sheets of glass glued together, stoppered at one end, and filled with water. (Or... Hm. What's the refractive index of lamp oil? Lower or higher?)
Feb 6, 2011. 3:25 AMKiteman says:
You can buy clear resins as well - "fake water" etc.
Feb 7, 2011. 11:58 AMorksecurity says:
Good point. I remember casting some biological specimens in plastic, back when I was a kid. (The resin used for the purpose actually penetrated the tissues and made internal details visible; impressive.) Something like that which is very transparent, polished appropriately, seems entirely reasonable -- assuming that it is a dispersive medium (which it probably is).
Feb 4, 2011. 2:04 PMsteveastrouk says:
That's another classic method, for toys.
Feb 5, 2011. 1:14 AMrickharris says:
I have hand ground and polished small prisms, it's very hard to get the angles spot on!!!
Feb 5, 2011. 8:17 AMrickharris says:
In acrylic. A triangular container and water works.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
