Electronics and Microcontroller guide?
Thanks!!
Wes
comments
Add Comment
My advice is to get hooked up to the MAKE community. They are always presenting very simple ways to get into the Microcontroller (uC) scene. Check out this link for a book on some tips on how to get started with an Arduino Kit. Just a note: All Arduinos actually have Atmel brand uC's on them.
Other affordable uC Kits are the PICAXE line made with Microchip uC's and the Basic Stamp & Propeller Lines by Parallax which also incorporate Microchip uC's. Another Note: Microchip uC's are nicknamed "PICs" due to the prefix on the uC.
So I guess your first choice is to either go with Atmel or Microchip. You can check out a variety of different ones at: HVWTECH
My more biased advice to a someone just getting into micros is to go with an Atmel based Arduino kit for 4 reasons:
-There is plenty of supporting documentation
-You do not need an external programmer (if you have an FDTI chip onboard)
-The programming language (called Wired) is easy to learn
-The software is open-source (free)
DISCLAIMER: There are plenty of other uC's out there but they may not be as newb friendly. Other microcontrollers may require you to buy an external programmer, learn a challenging programming language, have expensive software, and may not have much support. But like I said this is my biased opinion, others may have a differing view on the subject.
By the way just for some Background info: I started with a Motorola 68HC11 & Microchip PIC16F877 (Pictured on my robot) in Tech school and found the software I was using at school was too pricey for me to use at home so then moved onto an Atmel ATMEGA32 Kit & then to more affordable Freeduino Atmel based ATMEGA328.
Good Luck, in the uC Wes, I promise you'll have a lot of fun!
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
