loading
Half broken monitor
I recently bought a 19 inch LCD monitor for 40 bucks (used). It works perfectly for about half an hour (i havn't timed it) and then the screen just goes blank. If i turn it off and then back on it works for a couple of seconds then it turns back off. If I let it be for a while (like an hour or just when I'm not using my computer) it works fine for another half hour. Is this an overheating problem or what is going on?
guyfrom7up (author) 8 years ago
if I use a fan where would I put it? Should I open it up? Maybe it's clogged up with dust?
It could be clogged up with dust, but that seems unlikely. There's very little airflow through an LCD.
If it's overheating, it's probably the power supply board that's overheating (you know enough to figure out which one that is). Replacing the overheating component might do it, but not if it's SMD...you're liable to cook another component, you clumsy oaf. :-P If it's an IC or similar device that's overheating, you might be able to attach a small heatsink.
The "liquid air" cans, when inverted, spray a very cold liquid, which can be used to determine which component is overheating.
thats sounds like a bad idea. spraying freezing liquid on a hot component... thermal shock, shattering of silicone (glass) internal chips ........
Standard procedure, actually. That's why you can buy cans of "Freeze Spray." However, more people have cans of liquid air than have cans of freeze spray.
wow. okay, my bad. i was thinking cpu chips, where spraying freezing fluid on a 60 degree chip can be bad
i have determined that it has a malfunctioning inverter, when the light goes dark you can still see the image when shinning a light on it is there a quick fix for this?
guyfrom7up (author)  guyfrom7up8 years ago
suggestions? Do you think if i were to open it up it'd be a simple loose connection? Should I go buy some ccfl and inverters? Any info would be helpful
If the CCFL is still good, then you probably only need to replace the inverter. However, you might as well get replacement lamps while you're at it. It doesn't cost much more, and it will last longer.
NachoMahma8 years ago
. Sounds like an overheating problem. May be a component that has degraded and is more susceptible to heat. . If you are familiar with working around high voltage circuits, you may be able to pinpoint the problem component by using your finger as a heat sink. It may not be any warmer than the other components, but you may be able to soak up enough heat to get back in its' operating range. . Probably be a lot easier to just go buy another used monitor.
whatsisface8 years ago
Sounds like overheating to me. Try using a fan with it as well.
