loading
How can I turn on old tv zoom lens into a telescope
I have acquired a couple of tv zoom lens from canon tv station cameras. Does anyone out there know of a way to turn them into a telescope. Or ad a camera back attachment. It seems like a waste tossing them out. The lenses are fine, btw I'm cheap!
cbucci (author) 4 years ago
the lenses are a canon 9.5-143mm tv zoom and a 9-117mm any ideas or info I need to add.
Yes you can convert a old TV zoom lens to mini telescope. Actually Zoom lens itself is telescope (called as telephoto lens). You can look at a zoom lens as telescope without an eyepiece. All you need to do is first find the focal length of your zoom lens and make some attachment to it so that you can attach an eyepiece. For a simple eyepiece start with convex lens of 25mm Focal length
and see whether you are able to see far away objects. If things works go for good eyepiece for a telescope vendor.
BTW tell me what is the focal lenght of you zoom lens then I can give you more guidance.
Girish
Kiteman4 years ago
Without seeing the lens, or knowing the internal arrangements, my first thought is to simply mount a tube on the end closest to the camera to let the lens focus the light properly for your eye.
Hi,
Girish
You posted this as a reply to the user Kiteman, not as a direct response to the original author.
You may want to use the Add Comment link, and copy your text to a top-level reply, so that the original author is more likely to see it.
