How do I regulate voltage on a multi-amp battery charger.
I know very little about electronics. I have a car battery charger that outputs in 12 voltsDC. It is also "switch" selectible for 2 or 10 or 50 Amps. Once I select one of these choices 2/10/50, I would like to vary the voltage up and down from 1v to 12v. How do I build something that will vary the voltage at each of these amperage levels. Thanks- Steve
iceng27 days ago
If you succeed in setting the voltage to 1 Volt at the 50 Amp switch setting on a car battery you will suck 50 amperes out of the car battery possibly causing a Hydrogen expl_sion as it gets discharged !
iceng iceng27 days ago
The answer is you can not regulate the voltage of a Car Battery Charger...
But you can buy a variable voltage power supply
http://www.mpja.com/0-30VDC-10A-Variable-Benchtop-...
that is adjustable 0 to 30VDC and can deliver up to 10 Amps..
