3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to turn on and off a stream of gas?
The exact setup I have is a little difficult to explain, but basically I'm designing an extremely simple heat engine, based on boiling ethanol, and need to be able to mechanically alternate the flow of vapour.
I have a little boiler, sealed except for a pipe out of which the vapour escapes. This lifts the column of ethanol in the pipe, pouring it into a water wheel which turns. The ethanol then runs back through a second pipe into the system to be pumped up again.
It works, and fairly well since I'm not looking to get a lot of power or efficiency, but only if I pinch the tube on and off. This allows the bubbles to collapse, which sucks in more ethanol to replace them. When I release the tube the bubbles rush out, lifting the eths, and repeat. I have two valves to keep the system one directional.
So now I'm looking for a way to automate the opening and closing of the gas feed. I've been trying a few things but nothing seems to work well enough yet.
The other consideration is that; due to the nature of the larger project, whatever I use has to be extremely simple to construct, preferably from reclaimable materials.
1 second on, 1 second off seems to work best.
Any ideas?
cheers,
Daniel.
16 comments
May 15, 2010. 2:54 AMlemonie says:
I think you might be better with the cold-feed lower down?
L
May 13, 2010. 1:59 PMlemonie says:
Pinching increases pressure in the system, and raises the boiling-point. When you release you get a flash-boil by lowering the boiling-point quickly.
More heat is your best answer, after that - less volume/liquid/narrower-bore. You want this to run continuously without the pinch I think.
L
May 14, 2010. 1:07 PMlemonie says:
I seem to remember mentioning coffee-machines. You're giving me the vision of a vapour-shunt, where the system is spitting-liquid under vapour-pressure.
If that is the case, get a cheap coffee-machine and observe how that functions. Then utilise the non-return-valve from it.
L
May 15, 2010. 1:52 AMlemonie says:
Ball-valves should be OK, but maybe use plastic instead of metal. The coffee principle is to generate vapour at the bottom, which pushes liquid ahead of it further up. Then the vapour cools, contracts and the heater re-fills from the cold side of the system. I've had a stab at a ball-valve diagram
L
May 13, 2010. 8:36 AMcaitlinsdad says:
For what it's worth, www.dself.dsl.pipex.com/museum/power/alcohol/alcohol.htm
Wouldn't you make better use of the boiled ethanol vapor pressure to drive the turbine instead of it's liquid form splashing back down on the water wheel?
May 13, 2010. 2:14 PMNachoMahma says:
.  A relief valve may work. Or a check valve.
May 13, 2010. 12:16 PMcrapflinger says:
if you're looking to recreate exactly what you're doing now manually (i.e. pinching a tube...i'm assuming some kind of plastic) on a larger scale (or even the same scale) automatically, maybe you could use an electric motor, that's geared to make two revolutions a second. then attach a wheel on the end of the motor that has some form of protrusion. this protrusion would push on a dowel or a stick or something that would squish the tube between the stick and another stick, then the wheel would keep rotating around. it would take roughly a second for it to pass through the beginning and end of the squish, and roughly another second to make it back around to start the squish again.
May 13, 2010. 10:57 AMkelseymh says:
If you want to automate, you need something like a solenoid valve.  For a name-brand item, check Swagelok's Web site, or search McMaster-Carr's catalog.  Once you've identify the technical name for what you want, then you can do a Google search with that name and find something cheaper.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
