3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
IR Jammer
could some please show me how to build an IR jammer? I want one that broadcasts at all frequencies, as to not have to adjust it for each IR reciever. I would be most thankful.
13 comments
Feb 24, 2012. 1:50 PMmarinekid says:
in theory the simplest possible jammer would be an IR LED attached to watch battery with duct tape. Attach it in a hidden area an point it toward the IR receiver, it would blanket out any infrared light from any remote. Short range, not controllable, but extremely fun when you attach a magnet so you can magnetise it to a metal pylon or something.
Jul 13, 2010. 3:38 PMabbtech says:
This IR Jammer is exactly what you are looking for. http://alan-parekh.com/projects/ir-jammer-infrared-remote-control-jammer/
Apr 21, 2007. 7:33 PMDorkfish92 says:
http://www.i-hacked.com/content/view/34/89/Heres a link to one. I haven't made it yet but I plan to soon.
Jan 22, 2010. 5:08 PMGoodhart says:
Well ONE problem I see already is that the parts list says  R5 see note....and the note says:
2. You may need to adjust the value of R3 for the right frequency. A pot can be used.
Once that is worked out,  it should work, if you haven't over heated the transistors while soldering (common mistake is to forget to heat sink them during soldering).
Since different brands of Transistors can have a different EBC order, it is always good to check out the spec sheet of the manufacturer before solderin.
Apr 20, 2007. 9:56 AMandy says:
The way i would get it to work is to flood the area with random data, You would have to cycle between transmission frequencies, you would probably need a 555 timer and some way of altering the resistence/capacitence, you`ll probably need some tranisters for that and some way of produciong a sine wave/ saw tooth wave. Alternitivly you could use a programmed chip to simply bounce between low frequency and high frequency, or go for random variations, using a data table or similar... You could probably pull it off if you are running it at >1Mhz clock speed. Hope this helps, Drew
Apr 14, 2007. 9:41 PMmicroman171 says:
oh.... I was about to try it... Ill try it anyway and tell you how I get on
Apr 14, 2007. 10:18 PMmicroman171 says:
I tried it and no sucess but I have a plan so ill try dat
Apr 14, 2007. 10:24 PMmicroman171 says:
I cant figure it out (I have the logitech 380 (I think) universal remote.)
Apr 14, 2007. 2:25 AMmicroman171 says:
I think for it to work it would need different frequencies.... Not all of the remote are the same. But here is a link to make on: http://www.aaroncake.net/circuits/jammer.asp
actually by the looks of things this one just floods the place and completely corupts the data stream.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
