loading
Making a Chandelier with both LED and Incandescent light sources
I have just started to make my own chandeliers and would like to incorporate LED lights along with normal incandescent or compact fluorescent bulbs.  Do I need to add a resister with the LED light.  All the cords are being wired together as you would any other chandelier with multiple light bulbs.  I am a little confused when it comes to adding in an LED.  Please Help!
kelseymh6 years ago
When you say "incorporate LED lights," are you imagining individual little LED "dots" (like the usual 2-3 volt dome-shaped indicators, or what you find inside LED flashlights)? Those would require a separate circuit to reduce the 110V (or 220V if you're outside North America) mains voltage down to the few volts the LEDs require.
If you just want to use screw-in commercial LED bulbs along side incandescent or CFL bulbs, that's trivial. All of the necessary circuitry is included in the screw-in bulbs, and you don't have to do anything special.
Could you clarify, in the text of your posting (by using the [Edit Topic] button), what you have in mind?
yard ducks (author)  kelseymh6 years ago
Sorry, I'm new at this. I am using the screw-in commercial LED Bulb with an incandescent bulb. Thanks for your answer, I figured the circuitry was included but wanted to make sure.
