3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wind harmonic generator?
I had this idea a while ago. There's a nylon strap strung between two trees. It's let's say 2 cm wide and 5 meters long. A strong wind is blowing across it so that the strap is resonating, displacing through, say, 20 cm at 10 Hz. What is the maximum power involved? If you had one or more wire coils running the length generating current, what kind of efficiency over all could you expect? I'm thinking of this as an ultra cheap and easy means of wind generation.
9 comments
Aug 10, 2009. 11:30 AMTool Using Animal says:
I took a break from yard work, using your numbers for dimensions the area swept is 1.33333 square meters so the max power using say 7 m/s wind speed is 288 watts.
Aug 10, 2009. 5:21 PMTool Using Animal says:
he width of the tape isn't in the calculations, I just calculated the power of the wind for the area defined. There would be some happy medium where the width of the tape maximized the energy capture of the wind, but I don't know what it is. That's funny your thinking of that, I just finished a feedback class and have been thinking of building a windbelt that is always in resonance across a range of wind speeds.
Aug 12, 2009. 5:30 AMPKM says:
I'm not sure about that- it seems like when the thing is resonating it would be under more tension so would work against your tuner to detune itself enough to reach the balance point between the two forces. Also consider that IIRC, when you load the tape (as an electrical generator would do), the resonant frequency will move. I'm not sure how you intend to generate the electricity but a reciprocating linear motion is usually best rather than twisting motion.
Aug 13, 2009. 3:33 AMPKM says:
I suspect that bending/twisting the coil would have to happen in a magnetic field, so the current would be generated in the usual way (a wire moving relative to a magnetic field). I'm not sure if this method is used in many practical applications, I believe rotary or back-and-forth motion tends to be more practical. The diagram in your link shows what I was thinking of- as the belt "flaps" you capture that motion and use it with a conventional moving magnet/coil arrangement to generate power. I'm always surprised at the efficiency you can get from this sort of generator, though I'm not sure the windbelt is the most efficient way of capturing wind energy (though it has the obvious advantage of mechanical simplicity). You seemed to do pretty well with the solar tracker/collector, why not rig up a test model or two and see how much movement you can get from the windbelt before adding the generator?
Aug 10, 2009. 10:24 AMTool Using Animal says:
I also wanted to add that since you have a length and a max displacement you have three points from which to determine the equation of a parabola (which this can be modeled as) than simply integrate from 0 to L and multiply by 2 to get the actual area. Or you could model it as a sine wave, whatever.
Aug 10, 2009. 9:40 AMTool Using Animal says:
You need to calculate the area swept by your ribbon, then Max power is calculated by
.5*rho*area*velocity of the wind3 Where rho is the density of air (1.23 kg/m3)
Your actual power will be some small fraction of that number
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
