how do i solder a perf board?
i got a perf board for Christmas but have no i idea how to solder components together. i know how to solder the components on the board but i don't know how to connect them. do i use a jumper and if so how do i use that? isn't a jumper kit just some solid core wire? i have some .032 inch diameter copper wire from a transformer and i was thinking i could use that instead of a jumper?
guyfrom7up9 years ago
Yep, just use some solid core wire. I've always hadtrouble soldering pref boards because the solder always clumps together and you overheat the components
clip on soldering heat sinks......they do help :-) (normally I just use hemostats)
no problem
there's 2 tecniques, You could wrap the wire around the components leads, then solder. This is alled wire wrapping. You can also put the 2 ends of the jumper right next to each components hole and create a solder bridge over to the jumper
