3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
A Simple Hollow Grinding Jig
  • last photo ←
This is a jig I threw together from things in my shop that makes it easy to create hollow-ground knife bevels. I would have made an instructable out of it, but I don't have any pictures of the process and it's pretty easy to see how the thing goes together any way. The metal widget with the springs is there just to make sure the work rest (the piece of cherry with the c-clamp on top) doesn't move around and change the distance of the knife to the wheel. The c-clamp itself is cut down so I have a better view and control of the knife while grinding. I can also move it around to accommodate blades of different widths and thicknesses.
This jig could also work for with a bench grinder with a hard wheel. The roller that makes my hollow edge only has a 4-inch diameter, which is a little small for single edges...but it's the best I've got right now. And the blades end up devilishly sharp.
The last few images are of a knife I recently made with this jig, what I'm calling a "camp seax." Straight edges are easier. If you've seen my knifemaking Instructable, you can tell that I've greatly improved in a couple years.
11 comments
Mar 4, 2012. 10:52 PMripit says:
just bein nosey here,is the base of yer jig a chunk of purpleheart?
Nov 29, 2011. 12:04 PMreedje777 says:
I'd like an instructable on how to build your grinder. Where'd you get that?
Mar 29, 2011. 6:52 PMfishcake27 says:
hey basta, about how much did this cost completely?
Apr 4, 2011. 12:40 PMfishcake27 says:
thx... again
Feb 25, 2011. 6:00 PMpfred2 says:
I like it! How do you adjust your belt tracking?
Feb 26, 2011. 7:46 PMpfred2 says:
Oh OK I thought you'd made the whole belt sander attachment I see it now you made the tool rest. I've made a few tool rests myself. I've modified this one a little more since this picture but this is the general idea:
http://img37.imageshack.us/img37/1992/pict0241.jpg
For hollow grinding chisel and plane blades mostly.
I made this other one first though sort of a proof of concept before I committed to doing it in steel:
Feb 26, 2011. 7:52 PMpfred2 says:
I just found another picture of that tool rest more recent:
http://www.instructables.com/files/orig/F39/HOKU/GKGL5JHO/F39HOKUGKGL5JHO.jpg
I didn't know I could get the original resolution on this website of uploaded images.
Jul 24, 2010. 2:54 AMcaarntedd says:
This is pretty good, and I think if you set this out as an instructable with notes to go with each of your pics, you would have a decent 'ible. None of your parts look difficult to make. Great work.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
100
Author:Basta
