Introduction: Achu Murukku: a Sweeter Version of Murukku Variety of South India
Murruku is a South Indian crunchy snack food made mainly with rice flour. There are so many different varieties of Murukku. Achu Murukku is a sweeter version of this South Indian fried food made using a mold.
In Tamil language, Murukku means twisted because of its shape and Achu means Mold: Here a flower shaped mold is used to make Achu Murukku.
Step 1: Achu Murukku Mold
The mold used to make Achu Murukku is made of thin metal sheet shaped like a flower. A handle, about 12 inches long, is attached to the center of the flower shape. When you hold the handle perpendicular to the ground, the flower shaped mold stays facing downwards. These type of molds are readily available in Crocery shops in South India.
Step 2: Ingredients
- 1 cup raw rice flour
- 1/2 cup maida / all purpose flour
- 1/2 cup sugar powder
- 1 cup Raw coconut
- 1/2 teaspoon of salt
- Oil for deep frying about 300 ml
Step 3: Flour Mix
Mix Rice flour, Maida / all purpose flour, powdered sugar and salt together in a bowl
Step 4: Coconut Milk
Using a mixer / grinder, grind the raw coconut with water and extract the milk. About one cup of coconut milk is required to make the batter.
Step 5: Batter
Add the coconut milk to the flour in the bowl and mix well with a spoon. Make sure that there are no lumps in the mix. Also, the batter should not be too thin or too thick and should be of medium consistency.
if the batter is too liquid it will not come out of the mold easily and if it is too thick you will not get crispy Murukku. Adjust the liquid consistency accordingly.
Step 6: Heating the Oil and the Mold
Heat about 300 ml of oil in a frying pan. Here I have used refined Rice Bran oil.
When the oil is hot, dip the mold in oil and keep it for about a minute.
Step 7: Molding
Immediately after taking out the mold from hot oil, dip in the batter to about two third depth of the mold. Do not dip the mold fully in the batter. When removed from the batter, you can find a fine layer of batter sticking to the mold (See second pic).
Deep fry the Murukku in hot oil by holding the handle of the mold. Keep the oil to medium heat.
Step 8: Removing From Mold
When the Murukku is fully fried, remove the mold from hot oil and drain out excess oil.
Using a fork, press down the Murukku from the mold. It is very easy. The murukku will get released from the mold and will be somewhat flexible. Allowing it to cool will make it crispy.
Enjoy...!!!
First Prize in the
Fried Food Contest
