Arduino - CLAP SWITCH - SOUND CONTROL SWITCH
Published
Introduction: Arduino - CLAP SWITCH - SOUND CONTROL SWITCH
About: Hello world! I make simple & Advanced projects for people who want to learn programming and electronics. Most of my Instructables are about arduino and the wide range of sensors you can use with it. I ma...
Hello world! Today i made a clap switch with a DIY sound control module. I soldered the Sound control Module a few months ago, and today i decided to check out if it works, and it does. I had a hard time getting another value then 0 and then found a way to get 2 values. You can clap, knock, or say any word + you can blow into it.. for the last 2 you need to be close to the device. You can also use it as a shock/knock sensor. Check the next step for the schematic Code & Parts list.
For the Sound Switch Module:
Attach the Blue wire to SCL on arduino.
Attach the Yellow wire to RXD.
Attach the + to VIN.
- to ground.
Step 1: Schematic Code & Parts List.
Just connect it like the schematic, upload the code and it should work.
Parts list.
  1. Arduino uno, i used the RobotDyn Uno.
  2. KY-019 Relay module. Any other will work to, or make your own relay module.
  3. DIY Sound Switch Module. (You need to solder it yourself)
  4. 9v 1000ma AC/DC adapter
  5. Lamp socket + power cable. (optional)
Good luck!
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    • Creative Misuse Contest
    2 Discussions
    Can the output for my lights be 12V? I'd like to clap and turn on a strip of LEDs. Thanks.
