Back in the 1920s, a young man named Thomas Townsend Brown discovered that if he charged a capacitor with high voltage direct current, the capacitor would exhibit thrust in the direction of the + positive electrode. Off and on for the rest of his life (he died in 1985) he worked on these devices, trying to make a practical propulsion device using this principle. While in college, Brown worked with physicist Paul Biefeld, and the professor's name was added to Brown's when the phenomenon was named "the Biefeld-Brown Effect" (hereafter "B-B").
Basically, a B-B device consists of a small or sharp electrode separated by dielectric material (an insulator, in other words) from a large or blunt electrode. In this form the device is a type of capacitor. When fed high voltage (20,000 volts) DC current, the capacitor will develop thrust leading from the small/sharp electrode and away from the large/blunt electrode. Brown maintained the device thrust toward the positive + pole and away from the negative - pole, but modern experiments have shown the B-B effect works in either polarity. What is important is the electrodes must be differently sized--hence an "asymmetrical capacitor."
A lot of people maintain the B-B effect is electrogravitic; that is, the electrical current acting on the capacitor somehow counters, or interferes with normal gravity. I do not believe this. The effect is clearly the result of excess ions being thrown off the small/sharp electrode, flowing toward the oppositely charged large/blunt electrode. In normal air, the ions pick and charge air ions, adding to the cascade and increasing the thrust. In a vacuum, or under insulating oil, asymmetrical capacitors can still exhibit thrust, though it is usually much weaker. This is because only the ions coming off the forward electrode are present without charged air ions to help push.
This Instructable will describe how to build twin rotary thrusters as a demonstration of the Biefeld-Brown effect. If you prefer to believe this is a form of anti-gravity, you are welcome to do so. My purpose is show you how to build the device, not debate Brown's electrogravitic theories.
New video of the thrusters with a different power supply:
Another video showing the ACTs powered by a handcranked Wimshurst machine:
Remove these ads by
Signing UpStep 1Parts you will need
1 polyethylene cutting board, 14 x 17 inches by 3/8ths inch thick
other sizes and materials will work; wood will do if you coat it with insulating varnish
5 feet of 1/2 inch PVC tubing
ordinary hardware store plumbing pipe, white
2 1/2 inch PVC "T" joints
1 1/2 inch PVC 90 degree elbow
5 1/2 inch PVC end caps with flat ends
A lot of pipe caps come with rounded ends. Try to find squared-off, flat caps.
See http://www.creativeshelters.com/fittings/Display-All-PVCFittings.aspx for example
1 1/2 inch PVC plug
10 inches of 1.25 inch (about 40 mm) cardboard tubing
I got this from a roll of holiday wrapping paper. It should be as light -weight as possible without
compromising strength
2 12 oz. aluminum soft drink cans, any brand
2 aluminum discs, 40 mm diameter
Again, these should be as thin as possible to save weight, but be rigid too.
a few square inches of rubber sheet about the thickness of a coin
Foam rubber will do if it's dense
4 rubber appliance "feet" with 1 screw each
about 14 inches of 1/4 inch hardwood dowel
Poplar, basswood, etc.
6 feet of 22 gauge bell wire
6 8/32 brass bolts, each about 1 inch long
1 8/32 brass bolt, about 1.5 inches long
2 aluminum 8/32 threaded spacers, about 1 inch long
1 8/32 washer (brass, aluminum, or steel is OK)
3 knurled brass 8/32 nuts
3 8/32 brass hex nuts
1 resistor, about 4 megaohms
shellac or polyurethane varnish
Super glue
aluminum HVAC tape
tube cutter, scissors, sharp knife, paper hole punch, a drill with 1/4, 1/16" and 8/32 bits
power supply--see separate page for info
PBT
http://projetmontgolfier.info/INTRODUCTION.html
I believe the Bahnson series of experiments also claimed some thrust in a vacuum, but I'd have to check.
Certainly under the right conditions (not in this device!) ionising the electrodes could occur. Isn't this the basic principle of the ion enginem a substance like caesium as the ion fuel?
I use the term cascade in its ordinary meaning, "a connected series, as of amplifiers for an increase in output." I suppose a better term might be an avalanche, wherein a small disturbance grows larger by taking new portions with it. The language is merely meant to be descriptive, not definitive.
Don't get me wrong. This effect is caused by ions. As I said, I don't believe in anti-gravity.
PBT
PBT
http://www.youtube.com/watch?v=-eqU1bDFtgI&feature=mfu_in_order&list=UL
PBT
THIS IS EXTREMLY EPIC!!!
Higher voltages give greater thrust. Tests have been made with B-B devices up to 300,000 volts and more.
PBT
But can I use a 555 driven Flyback to drive it? it can put out well over/under 20kV and it's rectified.
(Also about the CRT, when you take out the suction cup touch it to ground also take a ground wire and touch the hole where the suction cup was, just to be safe. Some monitors have up to 75kV inside and that probably will kill you. )
CRTs need to be handled carefully, that's for sure.
Paul
Hehe learned that the hard way years ago...
Really cool instructable btw!!
Give it a try!
PBT
PBT
PBT
WE'RE IN THE WRONG TIMELINE, MARTY!
Match this engine up with this baby:
http://technabob.com/blog/2010/08/14/life-sized-tie-interceptor-star-wars/
and we can start our galactic empire!
Wow, ill have to look into this, Bizzare
And maybe next time you can narrate the video.
I had to stop watching, Like watching grass grow.
"Lifters" are a interesting related device that is easy to duplicate. A quick google search will bring up JNL Labs and other sites.
I have used some in my HHO projects that work just fine!
PBT
A simpler EHT supply could be designed using an EHT transformer with a wire looped twice around the ferrite and the ends of this wire connected to an electronic halogen transformer and a halogen bulb as a dummy load. The electronic halogen transformer could then be connected to a conventional mains dimmer. up to 65KV can be generated off a surplus EHT coil in this manner.
All sorts of DC power supplies are possible. I chose the CRT as being the easiest to set up.
PBT
A very very low powered Ion "engine".
I did a similar project in school and made little rockets on a pendulum causing them the swing.
Cheers! :)
Site
Paul
Cheers! :)
Site
*now is thinking of Bride of Frankenstein but that's for another post*
Cheers! :)
Site
I didn't know this was possible!
Nice creation ;)
