It was developed by Dr. Richard Wallace and followed by other likeminded programmers (AIML free software community). An A.L.I.C.E. ("Artificial Linguistic Internet Computer Entity") AIML tag set was released under GNU General Public License (GPL).
There are different AIML interpreter on the Net like AIMLbot (Program #) (.NET/C#), CHAT4D edit and run (delphi) (french), ChatterBean (Java), Program D (Java, J2EE), Program O (PHP/MySQL), Program Q (C++, Qt), Program R (Ruby), Program W (Java), RebeccaAIML (C++, Java, .NET/C#, Python, Eclipse AIML editor plugin), and others. Most of AIML interpreters are open source programs.
The Loebner Prize for artificial intelligence ( AI ) at http://www.loebner.net/Prizef/loebner-prize.html is designed to implement the Turing Test which will prove the most human-like computer that "think" using the AIML.
The 2008 winner is Fred Roberts and Artificial Solutions of www.elbot.com
Now, I'll teach you how to make your own AIML file ready to be put inside the "brain" of your robot using the "simple" Windows Notepad. This is a basic AIML coding instructable. You do not need any AIML editor or AIML file creator or even AIML parser chatbot editor. We will simply used Notepad. That's it, you see it right, Windows Notepad!
Even if you do not want to make an AIML file, you can still use the basic AIML coding tutorial which you can find in this instructable. You can save it as XML for integrating into a Javascript-based or Flash-based website with AIML interpreter.
There are other application programs that extended the capability of Windows Notepad such as NoteTab, Crimson Editor, VIM, Boxer Software Text Editor, Rogsoft Notepad+, ProNotepad, Notepad++, Notepad 2, Metapad, NoteXpad 2.0, etc.
But in this instructable I simply used the Window XP notepad. Beware, Notepad programming can either make or break you.
This seemingly innocent application can do things that are really astounding and to some will find them shocking and alarming as shown by the following: format your computer's HDD, lock a folder, make a digital diary, create a cycle message, shut down your computer, "hack" the administrator account, toggle caps lock button, continually pop out your computer's CD drive, hit Enter or Backspace simultaneously, automatic keyboard typing, open Notepad continually, change text header and footer, print tree root (directory or location of file), access CMD, write virus programs, play sound, flood files, create hidden text file, make a matrix falling text effect, program chat codes (VBS), make your computer talk, make your own autorun for your CD and DVD, open and close CD-ROM, increase Internet speed, add your photo in computer properties, test your anti-virus software (active or non-active), add shutdown option in right click, make a timer, etc.
You see Notepad is not just a simple text editor as many thought it to be. You can make different types of files (not just only TXT) by means of Notepad with the following extension names: HTM, HTML, XHTML, XML, WML, CSS, JS, BAT, VBS, EXE, PHP, etc. It is so amazing, isn't it?
PERIANDER A. ESPLANA
codename: "theseventhsage"
http://thebibleformula.webs.com
http://www.internetsecretbook.com
Remove these ads by
Signing UpStep 1Open Notepad.
1. Start -> All Programs -> Accessories ->Notepad.
2. Start -> Run -> In the Open textbox type "Notepad" (without quotation).
I have made a chatterbot at my home. I am ninth grader. I have programmed it in C. i have not used open source programs. Later i was introduced to cleverbot and then AIML . So what do you think making a chatterbot will be easy in C or AIML
http://www.pandorabots.com/pandora/pics/tutorial/en/tutorial.htm
http://www.computerhope.com/jargon/p/proglang.htm
http://www.historymania.com/american_history/AIML
http://program-n.sourceforge.net/index.html
http://www.tunetrackersystems.com/tips/topics.html
http://www.square-bear.co.uk/aiml/
You comment applies to hypertext markup language (html):
http://www.cs.tut.fi/~jkorpela/prog.html
That was from your website that you cited. A markup language is NOT a programming language. HTML and XAML and the others are called markup languages for a reason.
