Build a Fibonacci golden section gauge for $1
 by matthewtmead
Featured
Step 4: Cut gauge pieces
In this step we cut out the pieces using a band saw.
With your safety glasses on, start by slowly rough cutting all pieces from the large cutting board. This is to ensure you don't accidentally cut into an adjacent piece as you are every so carefully cutting another piece. Go slow.
Once all the pieces are rough cut, slowly keeping an eye on your line, cut each piece. The secret of the bandsaw is to cut close to the line, but not on or beyond the line. You can easily use sandpaper, a sander or file to clean up the pieces once they are cut. Because I was taking my time, I spent about 20 minutes making all my cuts.
Cut your pieces slowly. If necessary, you might not be able to make all turns with your blade, so you might have to make multiple cuts and end up having smaller pieces being cut out.
If you have any small pieces of plastic get stuck in the mouth of the saw table, turn off the saw, wait for it to stop, and remove it before continuing. As you are cutting your pieces, you will notice that plastic is cut away and partially melted and is left hanging from the bottom of the cut piece. You should remove these pieces with a metal file.
Finally, using a file or sandpaper, make sure all pieces are smooth and that any irregular bumps are removed.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
