3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a Programmable Mechanical Music Box
If you've ever seen those little music boxes you wind up, or crank, and they play a little tune over and over from a little metal drum of notes, but wish they did more than play the same 10-second tune over and over for eternity?  If only you could change the song and write your own music for it... Now there's an idea.
After a year of design and work, I completed my Re-Programmable Music Box / Mechanical Synthesizer / Organ Grinder Thingy.  It has many names, and is 100% non-electric.  Just wood, metal, and good ol' people power.
I began this project as a sort of proof-of-concept, designing something from scratch without a lot to base it off of, and a whole lot of engineering problems to solve.  Also, I didn't really know what I was doing.  It was intended to be a learning and problem-solving experience.  And it was a lot of fun.
If you like my work, please vote for it in the Woodworking Competition beginning October 3rd.
Step 1Design and Planning
Design and Planning
Since this project was starting entirely from scratch, I needed to make a flawless design that could be easily worked with, and a good design always reduces waste.  I decided to use oak, and at $60 per 10ft plank I didn't want to waste any.  Also, its pretty complex and precision is extremely important for everything to work correctly.
I started with the idea: a large wood cylinder will hold metal pegs.  It will rotate and force the pegs to pluck metal tines, which are tuned to specific notes.
I selected 12 notes across, since it seemed like a very flexible number of notes and allowed me to fill it with a simple 8-note scale in the middle, with a few extra high and low notes.  I could also tune in flats or sharps if I wanted some specifically, or get almost all of a chromatic scale in.  I selected 32 notes "around" the cylinder, because that's what you need to play Pop Goes The Weasel, or any 8-bar song using quarter notes.
The cylinder is made of softwood, 8" in diameter, that I picked up from a nearby carpenter for free.  I found a belt that fit snugly around it to use along with a few gears and a belt for the cranking mechanism.
The tine material was cut from the prongs of a garden rake.  This works great because it is flexible but snaps right back into place.  The tine holder design was sort of up in the air until the rest of the machine was done, so that I could do testing.  Initial designs were too complex and tiny, but the final design (image 3 below) is about as simple as possible, I believe.
Originally I wanted to use almost all wood for this project, but it turned out wood wasn't going to offer the precision that I needed for the tines.  I ended up doing it with a CNC at my college.  In Step 7 I hypothesize how it could be accomplished without such expensive tools.
When designing the wooden frame, try to place the pieces to get as few exposed edges as possible.  The edges you do have, try to align them so that they create borders and still look appealing to the eye.
54 comments
1-40 of 54next »
Aug 31, 2011. 12:54 AMdrbill says:
If you turn the cylinder on a lathe you will have exact centers so the cyl will be tracking perfect.
Jun 18, 2011. 11:16 AMsydkin2000 says:
Whoa.............................................OMG i could not do somthing like that if i had my whole life to work on it........*Bows down to you*
Apr 27, 2011. 9:47 AMNaturalCrafter says:
I love mechanical devices so this one was way cool for me to read. Thanks for sharing.
Apr 18, 2011. 1:49 PMHarata says:
Do you have a video of it working? It would help convincing us to do it!
Anyway, it's a great work and I'm thinking about doing one myself! Thank you, it gave me a lot of ideas!
Sep 12, 2010. 5:04 PMcrash_gnome says:
Can we see a video of it playing something please I think its really cool and would like to build one alike but would like to know how it sounds first. Thanks and keep up the good work
Dec 31, 2010. 9:36 AMeranox says:
This is, to date, my favorite instructable! I'm planning to modify your design to make a musical jewelry box for my fiancee.
I understand your frustration in getting the cylinder precisely shaped.  I'm considering constructing mine out of more staves (maybe 24 instead of the 8) and possibly just forgetting about rounding it.  At those shallow angles, the pegs should have no difficulty plucking the tines.
Since you're having difficulty getting your cylinder to shape, perhaps you could mount it on a mandrel and use an electric drill as a makeshift lathe.  You could cap each end of the cylinder with a large metal disc with a hole in the center (basically a very large fender washer) so the pressure would be exerted evenly, and then run a length of threaded rod through the center and clamp the piece in place with a couple of nuts.  I use a similar method when building handles for my fishing rods, and the cylinder is big enough in diameter that I think you would get an acceptable speed of rotation on the outside face to effectively shape it.
Regardless, it's a really great project, and I'd be thrilled if mine turned out as well as yours did as-is.  I'd like to find a wind-up mechanism similar to what you see in commercially available music boxes, so that the cylinder doesn't need to be manually cranked, and the music would start and stop when the box was opened.  I'd just hack an old music box, but I doubt the mechanism would be strong enough for a cylinder this size.  Any ideas?
Jan 6, 2011. 6:33 AMeranox says:
My plan is to use a modification of your design in roughly the same dimensions as you built it, with a large box below to store the jewelry. I looked at some of the windup mechnanisms after I posted, and it's clear that you're right. No practical way to do it for something of this size.
The electric motor solution would work, but I feel that it would detract from the handiwork appearance of the music box, and I don't want her to have to hassle with batteries or an adapter. She won't mind the hand-crank mechanism, I think, so I'll probably just save myself the extra frustration and leave that as-is.
I tried my hand at a simpler project (basically a mitered box) to give myself a refresher before I ruin anything of this scale. I'm having a difficult time getting my cheap Skil table saw to cut miters accurately enough to make a box, let alone a cylinder. I think my best bet will be to only use 8 staves in my cylinder, as you have. Any advice on getting the cutting angle just right?
Sep 13, 2010. 10:26 AMjjgodinho says:
if your drum is off by milimeters, why dont you use a lathe to round it off? as for the project it is very well made, ease on the eye and with a professional apearence.
Sep 23, 2010. 2:01 PMrealalchemy says:
hello matthegamer
out of respect for the be nice policy i will be nice
i worked for over 5 years to come up with the idea of the mechanical kalimba
look at my blog timmymontanaautomata
its is an original idea of mine
it is wrong to enter a contest with a strict alchemist idea
Sep 16, 2010. 8:40 PMTaranach says:
You could try getting a very large hose clamp to hold the outer diameter steady while clamping to the inside.
Oct 5, 2010. 9:18 AMpaleotool says:
Wow! This is great. I want to build one very soon.
Sep 22, 2010. 9:57 PMpaqrat says:
Very very good instructable. It reminds me of an antique one we had at the store where I work. The major difference was size, it was a bit larger, mounted on its own wheels and that it had no tines but used piano (or guitar?) strings. As I recall the pegs on the wheel, which in the antique's case were nails positioned to play just one song, pushed spring loaded hammers like the ones in a piano. After the peg pushed the hammer forward enough to slip past the end of the hammer the springs would then cause the hammers to strike the strings. It had a pretty good sound. I think combining your idea of the cylinder with adjustable pegs with the hammers and strings would eliminate the need for the magnets and the resulting work in setting them. It seems to me that once working with the hammers was worked out it would be possible (using different sort of head on the hammers) to use something like a zylophone or marimba (sp?) or, on a smaller scale, bells.
The antique one had a cylinder that appeared to be a section of limb or tree trunk. It didn't appear to be that rounded but I imagine that, if only one song is to be played, the position could be tweaked as needed. One tweaking of each peg would be enough.
Sep 19, 2010. 5:36 AMjelleAtProtospace says:
Cool project! But why did you opt for the massive oak drum? If you use a cnc mill anyway, an easier solution would be to cut some endcaps from ply that accept strips of wood that form the surface of the drum. If you make each strip per count of your melody, all the holes would be oriented the same way, and still be easily cuttable with a 2.5d cnc router.
If you put a strip of iron at the back of your holes, you could glue the magnets to your pegs, and need much less magnets.
Another idea that springs to mind is to put a tuned resonating chamber under each tine (or per two, to halve the number of chambers needed). That might give it some more volume.
And a last thing: did you choose your gearing such that each forth (or second or third)count coincides with a downstroke of the crank?
Sep 17, 2010. 3:13 AMMadrigorne says:
for the parts of the cylinder that are not close enough to your comb - make the peg a bit longer - yes I know uniformity is awesome, but for the sake of mechanical usability - sometimes ya just gotta do it the way it works. I love this - will make one as soon as I finish my kabillion other projects...
Sep 20, 2010. 3:16 AMMadrigorne says:
or another little piece of metal - the magnetism should translate through and hold the whole stack together, like when you can pick up an whole pile of paperclips with one magnet...
Sep 17, 2010. 3:09 PMDagless says:
This is very well done. Thanks for sharing.
Can you tell us more about the pegs used – how did you get/make them, are they easy to move, are the magnets really necessary?
I think your tine and bridge design are excellent. I wonder if a larger body/thinner wood might give you better resonance though.
In the case of Pop Goes The Weasel, you'd be better off with 48 holes around the circumference (12 per bar for 4 bars) since it's really in 3|4 or 6/8 time. That wouldn't be useful for tunes in 4/4 though. 96 holes would be versatile. 4 bars at 24 notes per bar would give you the option of 1, 2, 3, 4, 6, 8, 12 or 24 evenly spaced notes per bar. It goes without saying you'd need a pretty big cylinder though.
I have theorised about a similar (much more crude) design. I was thinking of a large diameter PVC pipe for the cylinder, driven directly with a crank handle (without the gearing you have used). Each peg could be a nut and bolt - with the a nut glued to each hole in the PVC (effectively making each hole threaded) and bolts screwed in to strike the notes. Perhaps varying the height to which each bolt protrudes could affect the dynamics (loudness and softness) of the notes, or perhaps that would adversely affect pitch. However, you'd probably want an easier way of recomposing the pegs – e.g. some sort of springy push-pull pegs. The key thing would be to make it easy to create new tunes.
I am also very interested in rford's comments about punch cards. I would very much like to see this idea expanded upon. There is a simple music box available using this idea here: http://www.grand-illusions.com/acatalog/Large_Music_Box_Set.html
The potential is quite exciting, but I have no ideas how to implement this. :(
Sep 18, 2010. 5:00 PMDagless says:
I was thinking perhaps the magnets could be done away with by drilling the holes 7/8" deep on a slight angle so the angle upwards towards the tines as they rotate around, but of course if they weren't snug they'd just fall out as they rotated toward the bottom.
I agree that self-tapping screws in to wood would have a limited lifespan. And that simplicity and ease of re-programming tunes is key to functionality. Your magnet solution is the best so far I think.
Just thinking out loud: I wonder if my nut and bolt idea would be more feasible if the screw thread was much steeper, so that it only took, say, half a turn to set or remove the pegs? I don't know if such a thing exists though.
Another option might be to have all the holes filled with pegs/bolts screwed down flush with the cylinder and just unscrew those you want to protrude on any given tune. If the cylinder was wood, perhaps you could use internally threaded anchors set into the cylinder. Something like this:
http://www.kevinbrassind.com/images/brass-%20pool%20-cover-%20anchor.jpg
Anyway, once again, very nicely done and thanks for sharing.
Sep 14, 2010. 8:13 AMrford says:
Good work. It is going into my "must have" list.
What do you think of the idea of making it run on punch cards.
If the pegs were spring loaded, and only extruded where there was a hole in the card. It would remove the limit on the length of the song.
An extra row of pegs on the out side edges, with no notes. Just to register the card and feed it in properly.
Now if I could just think of some way to have it re-tune itself from the punch cards.
Sep 18, 2010. 5:07 PMDagless says:
Hi rford,
Can you elaborate on your punch card idea? I have found this existing product:
... but I can't get my head around how this works. The springs would have to be sensitive enough that the card prevents them from protruding but strong enough to pluck the tines without retracting.
Have you seen any Instructable on this, or similar products?
Sep 18, 2010. 8:05 PMrford says:
My idea was too make the springs sensitive so they are easily retracted by the card.
The idea was to have the tines would first impart a perpendicular force that would lock them into place and keep them from being pushed in as they pluck the tines.
I know it can be done some how, there are a lot of examples of card controlled music boxes.
Maybe we need a "destructables" where people take things apart to see how they work.
Sep 16, 2010. 11:57 PMjimwi says:
You don't need a lathe to make the drum parallel, just set up a sander or an angle grinder with a sanding disk on it to a fixed place, a strait edge and just move the drum in front of the sander. Rotate handle to take off high spots as you slide music box along strait edge. Hope this helps, good job.
Sep 16, 2010. 9:46 AMWildrat says:
When we get the major CME, I will have this PDF printed and ready to build, so I can supply Mechanical music boxes to everyone with a digital music device. I'll be selling the boxes for one ounce of gold, pre-orders can be made now since it won't be long now before the big CME.
Nice box man, I thought we were going to here some Scorpions though. Good Work!
Sep 16, 2010. 1:53 PMWildrat says:
Coronal Mass Ejection
End of civilization as we know it scenario
Gold will be a currency
All the dweebs will want music
sell it to them for 1 ounce of gold
Scorpions- a rock band
Sep 16, 2010. 6:54 AMcourtervideo says:
WOW!! This is a FANTASTIC project!
1-40 of 54next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
122
Author:mattthegamer463
