Some people do crazy things http://www.ledcontrol.narod.ru/eng/index.htm .
One problem building such a clock is to find a motor. The motor has to be silent, it has to make more than 25 turns per second and the power for the clock circuit has to be transfered somehow to the pov pcb that is mounted on the turning spindle of the motor.
Bob used a motor from an old floppy disk drive in his project. He modified the motor to use an extra coil as a generator for powering of the circuit. The motor that bob used was a non regulated one from a very old floppy disc drive. These are hard to find nowadays and the speed is not very stable.
Daryl bender http://www3.sympatico.ca/surfin.dude/creative/clocks/propclk/blick.html also modified a motor. Other people transferred the power using brushes. Brushes make noise, give bad contact and are ugly ...
One can also mount a battery onto the moving part http://www.atomicfireballs.com/pivot/entry.php?id=53#body , but this battery need to be replaced now and then.
Phillip used a fan as a motor and build his own generator http://www.activevb.de/rubriken/kolumne/kol_27/propclock.html .
Here are many links to different solutions http://www.luberth.com/analog.htm and pictures of clocks that use brushes to transfer the power to the pcb.
I decided to solve most of the problems by using motors of old 5 1/4 inches floppy disc drives. These motors are brushless dc motors that are very silent while running. They are cheap. The build rather big mounting platforms. The speed of the motors is rather constant because it is regulated. The motors should be found rather easy in surplus stores for a small amount of money.
Remove these ads by
Signing UpStep 1What you need
- two motors with working circuit boards
- one voltage regulator 7805
- one variable resistor (values depend on the circuit board. mine was 50k Ohms)
- one capacitor (value depends on the circuit board, mine was 10nF)
- glue, best use is epoxy based
- some material to fill "space! (I used broken experimental pcb boards)
Tools
- a soldering iron
- pliers
- solder
- screwdriver
- dremel tool
- ... the standard stuff ... ;-)
There is no ground in free air ... is it?
I use the sign that you see on the picture as a common signal. If I would have drawn a real ground, in terms of an "earth" connection, I would have used this symbol;
http://de.wikipedia.org/w/index.php?title=Datei:Symbol_Ground_%28common,_horizontal%29.svg&filetimestamp=20060626175918
Does a Wikipedia page for this, exist for the US also?
http://de.wikipedia.org/wiki/Liste_der_Schaltzeichen_%28Elektrik/Elektronik%29
25*60= minimum RPMs or 1500 RPM
