It is a cousin of the box weave, which I personally dislike, and therefore have not presented as an instructable. If you do know box weave, however, think of the Byzantine as alternating box weave.
Note! This instructable assumes that you have basic chain working skills.
You may wish to start with Paul the Mole's European 4-in-1 weave instructable to get you familiar with chain working. Euro 4-in-1 is excellent for making sheets of chainmail, and is a great beginner weave. I also have an instructable on making jewelry-size rings, and armor-size rings will be addressed in another instructable.
You will need rings and two pairs of pliers. If you're working with small and soft rings, you can use a ring-tool and a single pair of pliers. I work with tooth-less pliers, as teeth will mark my rings. For many ring sizes, you can use chain, flat, bent or needle nosed pliers, but for some sizes you'll need specific ones. Apply judgment as needed.
Ring size: I frequently use 18ga aluminum wire with 3/16" interior diameter as a good medium ring size. You can go with larger or smaller rings, though the wire-to-ID ratio needs to be within a certain range to produce aesthetically pleasing results. A small wire size with large ID will result in a rather... anemic looking weave, and a thick wire with small ID will be too tight to work with.
See the photo? The IDs are all the same, but the thicker wire looks better. Be careful not to go too thick, though--the weave will get too tight to construct.
If you are interested in additional weaves, let me know (though PMs, emails or comments) on what you want me to demonstrate. If you want an idea of what's out there, take a look at the chainmail gallery on my website.
New and shiny updated video on step 3!
Remove these ads by
Signing UpStep 1Prepare your rings
For this method of Byzantine weave, you want 4 open rings per 2 closed rings. These rings will be made into 1 unit of 2x2 for every 2 open rings. Let me explain:
Take one open ring and slip two closed rings on it. Close the open ring.
Take a second open ring, and slip the same two closed rings upon it. Close the open ring.
You should end up with a set of four rings where every ring goes through two other rings, no more and no less.
Once you prepare your 4:2 ratio of rings, you will be left with 2 open rings per 2x2 unit.
http://www.mailleartisans.org/weaves/weavedisplay.php?key=572
The tutorial is here;
http://www.mailleartisans.org/articles/articledisplay.cgi?key=13016
I created the weave in '05, and a user by the name of MrMaigo made the tutorial shortly thereafter.
byzantine sheet...its huge :D
6 in one is exactly the same as 4 in one, but each ring goes through 3 rings on each pass instead of 2..just a bit more dense.
Umm... My links keep fliping back and forth so the weave doesn't keep its shape. Do I have to use thicker wire (I am using wire about as thick as small paperclips)
that each ring in this weave, at an Aspect Ratio of 3 - will travel .28x the inside diameter per ring...
as in 10 1 inch id rings would travel 10x0.28 = 2.8 inches
a 17 inch chain would take 17/.28 = 60 1 inch rings (big rings for sake of ratio)
a 17 inch chain would take 17/(say 1/4 inch) / .28 ratio = 242 quarter inch rings
17/(7/64)/0.28 = 533 7/64th rings....
all these numbers depend on an ar of 3.
anyhoo...it looks as if this weave uses about 32/inch of chain
or each inch travels about 1/32" 'per ring' (or 2/64ths)
again each ring is 7/64"...and each ring travels 2/64", a ratio of .285
so...a 7 inch chain would take 7 / (7/64 / (1/.285)) = about 200 rings
