Introduction: Mega_Menu (batch File) V 2.5
:--- Edit: In the next version, my goal is to decrease the size of the code. In doing this, I have decided to remove Monopoly. I have officially started working on the next version, and a mistake I am constantly making is publishing it with bugs in (that I don't know about). To help prevent this, I'm looking for BETA testers to run the code and try to find errors. Tell me what you think. ---:
Version 2.5 has arrived. I know that the previous versions were full of bugs, but I've spent 10 hours nailing down everything, so it should be bug-free. In theory, that is. I've added heaps of extras, so any one of them could realistically stuff-up, even through my testing.
New features of V 2.5:
Document Creator - Covers all your documentation needs.
More games - Keeps you entertained if your internet gets cut off.
Formatted code - Let's the young developer not get a headache by reading it.
Less bugs - Less frustration.
New log in function - Very cool to look at.
Address Book - Keep track of your friends.
Known bugs:
-Encryption function doesn't work (I forgot to add a label)
And many, many more!
If you want a full list of changes then the file automatically creates a change log which can be found in the info folder.
You will no longer need to do anything other than copy and paste the code and stick it on notepad. The file will do the rest!
Let's get started!
Step 1: Creating the .bat File
Firstly, open Notepad.exe (windows button+R and type notepad.exe)
I used to have the code below, but certain occurrences has stopped me from doing that...
Just click on the file icon down below and copy it from there
The password and name will take care of themselves.
DO NOT EDIT THIS SCRIPT (the password and name will be changed automatically).
Well that's pretty much it.
I've also added Version 2.3.2 down the bottom for people having troubles with the choice command.
Step 2: Enjoy
Stats:
The Mega_Menu.bat file alone takes up 9114 lines of text and 308434 characters. That's 32384 characters per line.
If you would like anything else included in the next version please tell me and I will send word when it is completed.
I am also doing custom batch files for people for free! If you're interested then tell me and I will see what I can do.
If you need help with a batch file or you don't know where you went wrong, send me the batch file and I will try to fix it.
Step 3: Enjoy
Now that you have the batch file you can either save it in your documents OR you can save it somewhere then create a shortcut and save it in your startup folder. From there it wil start on startup. YAY!
Sit back, relax and enjoy
Oh and please point out any bugs so I can fix them. If you were redirected to the bug page it was probably because you typed in an answer that was not valid.
BTW: You must be admin to add/delete admin (if you are admin and it's not working then right click it and select "run as administrator".
P.S: Do not try to make yourself admin at school
Now, I hope you understand how much work I've put into this version. I've added 3000 lines of purely my code into this, and formatted about 6000 lines of it. It has taken me many hours to do this. I would be very unhappy if it doesn't work, so tell me quickly so I can fix it.
Disclaimer: I take no responsibility for any wrong doings caused by the use/misuse of this batch file or any knowledge anyone gains from this batch file.
