DIY Frankenstein Bulb
98,315
740
44
Published
Introduction: DIY Frankenstein Bulb
About: Everything Hookah Related!
Step 1.) Remove The Tab on the light Bulb
Step 2.break the insulation layer (black part)
Step 3.)  Break the fialament and pulling it out
Step 4.) Add Water to wash it out if white (if clear skip step)
Step 5.) Add Gel i ended up using a different gel i used a garage door lubricate instead of the hand sanitizer
Step 6.) Add Padding to bottom of box
Step 7.) Make an outline of the cut your about to do to fit the light bulbs in
Step 8.) Cut out the holes made with 7/8 bit
Step 9.) wire the leds two both battery terminals and the switch Refer To This Diagram  --------> http://www.youtube.com/watch?v=owgrUYC0Sfw&feature=youtu.be
Step 10.) Glue together and Turn On And Enjoy
Halloween Decorations Contest
Runner Up in the
  • Make it Move Contest
  • Oil Contest
    Oil Contest
  • Clocks Contest
    Clocks Contest
44 Comments
THANKS!!!! to everyone that favorited and viewed my intructable I Appreciate it. it means a lot to me and makes me want to strive to bring you the best intructables projects to you and DON'T FORGET TO VOTE THANKS AGAIN!!!!
A word of warning, if using one of those white incandescent light bulbs, the white powder inside contains mercury which is a very dangerous substance.
the white powder in an incandescent bulb is a kaolin powder. clay. it's not toxic. there's no mercury in an incandescent bulb.
Yea, it was the "Fluorescent" lamp I meant.
Please cite your source claiming that incandescent bulbs contain mercury.. Fluorescent lamps contain mercury and the white powder in them is phosphorus.   I don't believe incandescent lamps contain anything particularlly hazardous.  (all in the interest of correct information)  :-)
Sorry, English isn't my first language and I mixed up the names. Many apologies, and thank you for correcting me =)
I completely forgot to point this out thanks you so much and don't forget to vote for me thanks so much!!
You're welcome =)
Terrific video, you should get an award for it!
hahahah i agree but a feature will safice for now and thanks it means a lot to me don't forget to vote :)
Using more bulbs with something like the Cylon circuit could make this even more fantastic. Something else I've seen used to fill glass objects, and keep bubbles throughout it, is clear silicon caulk that is fairly cheep and comes in the big caulk tubes, might be a lot cheaper than garage door lube. Again Great Instructable.
Thanks for the tips i like the cylon circuit idea a lot thanks dont forget to vote for me thanks!!!!
Great Job, AC Moore (Arts & Craft store ) sells light bulbs (clear) that the bottom screws off and on $1.00.
@hohohe I didn't know that that will make it much easier in my future projects thanks!
I'm not seeing where you are sealing up the bulb. What's keeping the gel from oozing out? Is it when you hot glue the bulb to the LED?
don't use hand sanitizer , its flammable so yeah not a good mix with electrity
Great diy project. I will have to wait a few months now since I am late to the party
I'm building this now for my son to have a night light...what kind of lubricant did you use... I was thinking of using clear hair gel, but was interested to know what lubricant you used that was clear... Thanks.
