What Is A Jet Stove?
A jet stove is a small piece of contraption that uses alcohol as its fuel. It works when the can gets heated by the burning alcohol around it, heating the can causes the alcohol inside the stove to evaporate into flammable fumes, the fumes now exit the holes, the fumes now ignites into flames. It is a cycle.I used an Apple, iPhone 4G to take pictures of the project.
Here Is My Video:
Remove these ads by
Signing UpStep 1: Tools And Materials
Tools:
- Multi Purpose Pliers (Leatherman)
- Dremel (or similar)
- Scissors
- Sanding Paper (Fine)
- Marking Pen (Sharpie)
Materials:
- Alcohol (Ordinary/ Denatured)
- 2 Empty Soda Cans (Recycled)
- Super Glue (Gorilla)
![Priming Wick for Alcohol Stove [and Pot Stand]](http://www.instructables.com/files/deriv/FK2/8VFR/GP7IFJ91/FK28VFRGP7IFJ91.SQUARE.jpg)
Visit Our Store »
Go Pro Today »
But, how is it a "stove"? What can you "cook" with it? I thought anything to "cook" would crush the little can... so what could you use it for? I am by no means trying to disappoint you or upset you or be rude... I just would like some ideas on what to use it for (I got the idea for a little heating source lamp type thing)...
Going camping so I will use this when I go.
Oh and Great Instructable, this has many uses and could cook food during a power outage or other disaster.
One thing though, about the hole size, you state "not too big, nor too small".
Might be a good idea as to state what size you made yours. you can always say "It's not too critical, but mine were 1mm or 0.042 in.". just sayin'. Always a good idea to give exact information when instructing so the person learning will know to expect it to work as good as yours, if not, because they failed to follow instructions. But, hey, still a great instructible and hope to see more from you.
I will try to do something like this in the near future...
BEFORE you wash out the cans, fill them half full of water and freeze them.
Now, you have a solid core to back up the can while removing paint -- can even buff it off with a wire pad on a power drill if you want.
Let them stand and thaw, pour a drop or two of soap in and shake to foam, wash the cans out and proceed ...
Bravo !
In the images, you'll see a small metal 'dish.' That's the priming pan. Add a little fuel to it first, then fill with about 2 oz. of HEET through the top (two holes under the penny.) Then, light the fuel in the priming tray. This heats up the fuel as well as ignites the jets.
I've never used any kind of sealant. I get about 15 mins of burn time indoors, various outdoors (you may have a hard time keeping/getting it lit in colder temps, less burn time in windier weather.) Be sure to have a windscreen. Flashing will accomplish this. Also, for a pot stand - three metal tent stakes works great.
1: Use a wire brush attachment on your dremel to remove the paint from the can.
2: If you don't have a drill bit small enough for the outer holes, use a small nail.
3: If you get superglue on your hand, nail polish remover removes it with ease.
Hope i helped some of you out.
However, i ran into some troubles on the way...
So here are my additional hints for expanding the cut cans:
- Use a full (and prefferably pressurized) can to expand the cut one.
- Press the full can in the cut one and not the other way around (Cut over full)
- You can press quite hard if you add the water (see next point) to expand almost all of the cut can. I normally expand 2 third of the height of the cut can.
- Always put 5-10 drops of water in the cut can and dont turn them (The full and the cut can) over if they are inside each other. Now if you want to have them apart, simply hold your lighter under the cut can and the steam-pressure pops them right apart. If you expanded more than a few mm you have no other way to separate them again.
I often repeat the expanding 2 times till they really fit snuggly.
If you press the 2 cut halves together (one expanded, one NOT), be sure you have at least one hole already drilled to let the air escape.
It also helps to have both cut cans the same height: If the inner & top (hole-containing) can is around 1mm away from the cut line of the lower & outer can you know: This is the end ynd you shouldnt go any further.
I once made such stoves just for fun out of Coke and Redbull-cans... till i found out that a lot of people found them cool and i made a ton of gifts. :)
Here is a SIMPLE SAFETY FACTOR to incorporate into your project,put in (( STEEL WOOL)) ,this prevents pre-ignition(Explosions) in case other fuels are mistakingly used, by lowering ignition temperature.
