3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Multimedia LED Projector (video manual)
Step 7PCB Fitting
PCB Fitting
This is very important, as placing the LCD circuit near the LCD without blocking the LCD itself is vital for a good result.
1.- Place the circuit on top of the plastic that is holding the LCD and mark the two holes where the circuit will be fitted.
2.- File the holes a little bit until you can fix the screws you want to use. If you can take out of a old computer the type of screw I'm using (they are called standoffs screws), it would be better as these screws still separate the circuit from the case a little bit.
3.- Drill the case and, after protecting the LCD, use some epoxy to glue the screws.
4.- Fix the cables to something so you wont break it. I used a cable tie.
7 comments
Jan 15, 2010. 5:02 PMkaronth says:
Can you check the controller chip numbers for me please? From the video I can just read the manufacturer, Techwell.
I'd like to know if there's a way to add support for vga input to the lcd. What about the 10 pin connector?
Thank you in advance, really a great project!
Jan 7, 2011. 12:54 AMaekara says:
here is a link of a 3.5" lcd monitor that has vga in
http://www.lcdshow.com/3.5_6.4-10.4_LCD/3_5_vga_lcd/3_5_vga_lcd.htm
Jan 8, 2011. 11:40 AMaekara says:
yes i know but i cant find the price of it.i think its expensive
i was thinking of buying this but i have already buy an 3.5" lcd monitor from ebay
Jan 19, 2010. 1:11 PMkaronth says:
On page 11 of the datasheet it says that the chip supports digital rgb and vga input vith hsync and vsync http://pinouts.ru/Video/VGA15.shtml but since there is no breakout of those pins on the pcb i think it's not a trivial task.
There are also some registers to modify to get the digital interface working (datasheet pg. 45 i think).
I'm by no means an expert, i guess if you ask a question on the benheck forum thread the guys there can give you more info.
Mar 26, 2010. 2:50 PMB33T says:
 VGA input can be achieved with this:
cgi.ebay.co.uk/ws/eBayISAPI.dll
Jan 14, 2010. 4:25 AMAnnon201 says:
Those screws are called standoffs, and they are measured/identified by the diameter and length of the threading of the screw (as well as no. of threads per unit in length)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
254
Author:newtonn2(http://www.newtonn2.com/)
