loading
Haters of messy pan cupboards everywhere... rejoice! This quick cupboard door modification will leave you with more time to enjoy cooking dinner and sipping wine and less time searching for that elusive pan lid that's hidden itself inside your deepest stock pot or slipped down behind that slow cooker you've never used.
Don't have a local pound/dollar store to buy sticky hooks?? Try these from Amazon!
I first did a similar hack a few years ago whilst a student. Finding pan lids annoyed me as much then as it does now and so after seeing a very elegant solution on Instructables, I set out to make it even simpler. Having moved house several times since then, I was impressed when a friend improved on my previous idea, at which point I realised my current house has the same problem... PAN LIDS EVERYWHERE. iceng's uses the existing fixings in the cupboard, which made me think, can there be an even simpler solution? And, since my cupboard fixings were in the wrong place for his hack, here we are. Cheap and easily available sticky hooks.
Step 1: Tools and Materials
You will need.... *drum roll* ... sticky hooks and a pencil! That is it. I found these 16 hooks for £1 in a pound store. Be sure to choose ones that aren't too small.
Step 2: Marking
Hold up your selection of pan lids against the cupboard door. Things you may want to consider are whether the bottom one will stick out too far into your cupboard and interfere with objects sitting on the bottom shelf. Position it high enough that it won't do this.
When you think you've got a good layout, hold a pan lid up against the cupboard door and draw a mark in pencil at the 4 o'clock and 8 o'clock. If you draw them too close to 3 and 9 it will fall out, if you draw them too close to 5 and 7 it might not be so stable.
Step 3: Sticking
Peel the tabs off the stick pad and slap the hooks on the door with the hooks pointing to the approximate center of where the pan will be. No need to be too precise here.
Step 4: Enjoy!
We're done. It's that simple!
Enjoy your newly less hectic pan cupboard.
<p>I used Command brand hooks, three for the largest lid. Completely removable - no permanent impact.</p>
<p>What size hook did you use? All the ones I have tried have been to small to fit the lids.</p>
<p>item # 17003</p><p><a href="http://www.command.com/3M/en_US/command/products/~/Command-Large-Utility-Hook?N=5924736+3294529207+3294773688&rt=rud" rel="nofollow">http://www.command.com/3M/en_US/command/products/~/Command-Large-Utility-Hook?N=5924736+3294529207+3294773688&amp;rt=rud</a></p><p><a href="http://multimedia.3m.com/mws/media/1070098O/17003es-commandtm-large-utility-hook-instructions.pdf" rel="nofollow">http://multimedia.3m.com/mws/media/1070098O/17003e...</a></p>
Great idea, I'd been trying to figure out what to do with my pot lids for a long time. This worked great, and freed up a drawer!
<p>What size hooks did you use? My lids look like yours and I have tried several size hook with no luck. Thank you.</p>
I used these Command Large Utility Hook, White, 3-Hooks, 6-Strips (17003-3ES) https://www.amazon.com/dp/B000M3V8XI/ref=cm_sw_r_cp_api_N4kNybQWTHNYT
<p>that cool trick </p>
<p>Peel-off adhesives stick better if the area is wiped w/alcohol first and both area and stuckum are warmed w/hair dryer or even a wet washcloth (esp when applied to smooth surfaces). That said, the hooks I've bought from dollar stores usually fall off within a few months, and I've given up on them. If I WERE to use them for lids, esp glass ones, I'd drill a hole in each and secure with a tiny wood screw--1/2 inch max. OR: use cup hooks. I'd also put the heaviest lids closer to the hinges--the doors on most cabinets are just laminate-covered slabs of glued wood chips, very susceptible to weight pulling down on the hinges. Those are glass lids--heavy--not light metal.</p>
<p>Jeez, this is 3 years old. Recycling are we?</p><p>zapp</p>
<p>New to this also. Just because it's old news to you, doesn't mean is old news to everyone.</p>
Like the lids. Pots are just pots.
<p>What????? Not making any sense with &quot;Like the lids. Pots are just pots.&quot;</p>
<p>The pots suck. The lids came with them on bottom.</p><p>zapp</p>
I am new to Instructables so I'm glad this idea was recycled. It will make it so much easier to find the right lid, and my arthritic back and knees need that.
<p>100 screw in hooks for $3.00. Heat shrink cushioning and yes, the pots that came with the lids aren't anything special.</p><p>zapp</p><p>zapp</p>
<p>I tried this a couple years back. Be sure you get hooks with strong adhesive. After less than a week, mine came loose!</p>
<p>If you are questioning the strength of the adhesive, play it safe. Drill a hole in the hooks before attaching them, and then add a screw to reinforce it. If you are putting screws into a particle board or MDF core door, use coarse, deep threaded screws and take care not to over tighten them. The threads of standard wood screws are too dull and sheet metal screw threads are too close together. Both will do more damage than good to particle board or MDF.</p>
<p>yes... afraid the glass lids will fall and break.</p>
<p>The lids are more than likely to be tempered glass like the ones I have. I have dropped mine so many times and they have never shattered or broken. Glass lids have to be tempered in order to be used on the stove.</p>
<p>Grate I am going to try this one.</p>
<p>Doing this! Thanks for sharing the evolution of the improvements to this idea, as well. </p>
<p>I need this in my life - doing it tonight! Thank you!</p>
<p><img src="https://cdn.instructables.com/FZE/C8TO/IG2JNPMF/FZEC8TOIG2JNPMF.SQUARE2.jpg" style=""></p>
<p>Bought pots on sale at target. Slightly disappointed but I keep the hooks on hand and they made great storage solutions with addition of aquarium tubing. Did this about a year ago. <img src="https://cdn.instructables.com/FZE/C8TO/IG2JNPMF/FZEC8TOIG2JNPMF.SQUARE2.jpg" style=""></p><p>zapp images posted previously and here though comment seems to ignore the fact.</p>
<p>Great idea but you must make sure the lid handle will prevent the cabinet door from completely closing. I could be wrong but in the photo it appears to me that the handle of the lid would prevent that.</p>
<p>I think that If he turns it so the handle is horizontal it will just go over </p>
<p>Damn fine idea. Bloody great!</p>
<p>Fixings? Do you mean findings or hardware? </p>
<p>Love it! Doing it today!</p>
FantaSTIC!! And so simple! My lids were annoying me yesterday - I'm going tho do this today. Thanks for the post!
<p>Genius!</p>
<p>i need this in my kitchen </p>
<p>Awesome ... </p>
<p>Thanks!</p><p>I did it using vinyl-coated steel cup hooks from Home Depot (http://www.homedepot.com/p/OOK-7-8-in-20-lb-White-...</p><p>$2 for 4 screw hooks.</p><p>They screw into the wood for a bit more security. They can accommodate thicker lids if you use pliers to unbend the hooks a bit - just gotta be careful you don't rip the vinyl coating.</p>
<p>I did this and love it. BUUUT, I had to make readjustments. You need to watch how the shelves and lids line up. I couldn't close the door because the lids were in the way. But after a little relocation it's perfect. Less jumbled mess in the cabinet and easy to find the right lid. </p>
<p>This is genius. &deg;,&deg;</p>
<p>I just did this and love it. Fortunately I already had command strips. I'll pick up a few more and put some inside the cupboard as well. Thanks!</p>
<p>If you use 3M Command hooks and make very sure that the surface to which they are applied is clean, that will not happen. I hate to sound like an advertisement, but I swear by this brand for this kind of application.</p>
<p>My problem with this idea is that adhesives aren't forever; they will fail and usually at the worst possible moment. It's a nice idea, don't get me wrong, but those hooks need some form of more permanent help.</p>
<p>GLUE GUN</p>
<p>I would definitely add a small screw for peace of mind.</p>
<p>Was thinking the same.</p>
<p>I installed the same system yesterday after receiving online purchase of new pots and pans. I utilized cup hooks I had on hand with tubing slipped on for scratch protection. My wife loves it and it sure bears rummaging for the right lid. Excuse the multiple images. New to this.</p><p>Zapp</p>
<p>Awesome idea! I need all the space I can get in my tiny apartment. Thanks.</p>
<p>Great tip! Unfortunately, I live in a mobile home that has a hideously severe lack of storage and the smallest kitchen cabinets on the planet. To solve my lid storage problem, I took advantage of my pantry door and used towel bars.</p>
Awesome idea. I live in a travel trailer/camper. This will work in my pantry. Thanks for sharing.
<p>You're welcome ;-) Every little bit helps in small spaces!</p>
<p>Geat idea ,,I have same issue, i live in mobile too,, by the way love your outfit,lol </p>
<p>It's a pot lid, it's a mirror! :D</p>
About This Instructable
406,155views
1,767favorites
License:
More by Jayefuu:Beech Tray for Salt & Pepper Mill Omas Grünes Tomaten Chutney Disabling Contactless Payment on Debit Cards
Add instructable to:
