Embroidered Fabric Speaker
 by Plusea
Contest WinnerFeatured
Embroider highly conductive thread to make a fabric speaker coil. Then run an amplified sound source through it and hold a magnet close to hear it play. Sewing the coil takes longer than you might think!
Here some videos of what the speaker sounds like:
Here some links to further documentation and variations of the fabric/paper speaker coil and membrane:
>> Fabric speakers
>> Paper speakers
>> Embroidered speaker kit
>> Embroidered speaker kit page
Step 1: UNDERSTANDING HOW A SPEAKER WORKS
A speaker makes sound because an electromagnet (the embroidered coil) is mounted to a membrane (the fabric) with a permanent magnet close by.  When an audio signal is connected to either end of the electromagnet (coil) a fluctuating magnetic field forms around the coil, repelling and attracting the membrane from the permanent magnet. These vibrations happen so fast that we can barely see them, but the membrane moves the air around it, translating electrical frequencies into audible waves that we can hear.
Take a good look at the diagram and stencil on the other side of this sheet so that you understand what variables will influence the efficiency (volume) of your speaker coil before designing your own.
makeshop says: Mar 21, 2013. 6:04 AM
Hi can you explain why I must be solderable conductive thread, would this http://www.kitronik.co.uk/products/textiles/textiles-kits/individual-e-textiles-parts/small-conductive-thread-bobin-6m-approx/ sort of thread work either?
Plusea (author) in reply to makeshopMar 29, 2013. 11:52 AM
it doesn't have to be solderable. but it should be highly conductive. the thread you linked to has a relatively high resistance to it, for making a speaker coil. meaning your speaker will be quieter because the electromagnet will be weaker.
TCBTC says: Jan 12, 2013. 10:53 AM
Isn't it also possible to use lightly insulated wire so they wont touch?
boygenuis32 says: Dec 9, 2012. 11:08 AM
So I made two of these and embedded them in my hoodie! The sound quality isn't great, but it's still cool!
IMG_20121209_133030.jpgIMG_20121209_133100.jpgIMG_20121209_132928.jpgIMG_20121209_132913.jpg
Plusea (author) in reply to boygenuis32Dec 10, 2012. 9:23 AM
Oh cool!!! Thanks for the photos! It looks great.
dee4402 says: Dec 6, 2012. 7:43 AM
This is super cool! How do you think of all this stuff?!
boygenuis32 says: Dec 5, 2012. 9:57 PM
Made a version with magnet wire on felt. Waiting on some magnets to test it out.
agis68 says: Dec 2, 2012. 3:56 PM
very nice instructable for experiments. What if you place bigger magnet. I think the better sound quality was the speaker in a black fabric. Was really understood every single word of the song.....very neat.....keep rolling
Plusea (author) in reply to agis68Dec 4, 2012. 5:01 AM
you're right the black speaker sounds best, but it's not just the speaker it is also the audio source. for the black speaker the audio is coming from an mp3 player and being amplified by a commercial amplifier, but in the other videos the audio is coming from a cheap sound circuit found inside greeting cards and i am amplifying it with a transistor.
Justin Tyler Tate says: Dec 3, 2012. 2:11 AM
This project would make for good ear-muff-headphones, for the winter months.
Justin Tyler Tate says: Dec 3, 2012. 2:06 AM
Couldn't you stretch the fabric on a frame or use embroidery rings, before sewing the speaker coil, in order to keep the fabric taught?
DIY-Guy says: Dec 2, 2012. 5:52 PM
Plusea you wowed us again! Would you happen to be related to Thomas Edison by chance? :)
On another note, will this speaker resonate a little better with a firm frame of reference such as stretching the floppy fabric coil over a more solid hoop of some kind? Anchor the edges so to speak.
Arghus says: Dec 2, 2012. 12:26 PM
Sound quality seems awful.. A speaker like that will only be cool when it offers audio fidelity. Still cool project to show ppl how a speaker works
woz.artur says: Dec 2, 2012. 9:59 AM
Very nice, continue your R&D! :D
shazni says: Nov 29, 2012. 5:53 PM
Please may i know if i hook up both ends to a socket and then plug it in to a mp3 will it work? sort of like a earphone? or does it need more power?
Plusea (author) in reply to shazniNov 30, 2012. 4:45 AM
it should "work" but it might be so quiet that you can not hear it at all. at best you will hear it very quietly.
shazni in reply to PluseaNov 30, 2012. 12:18 PM
Thanks...i guess the idea i had is out...as i don't have much experience with amplifying and all those electronics... I haven't come to my electronic phase yet :-)
Plusea (author) in reply to shazniDec 2, 2012. 3:34 AM
no need to know much about electronics. just buy a cheap amplified speaker unit like this one:
>> http://www.amazon.com/X-Mini-II-Capsule-Speaker-Black/dp/B001UEBN42/ref=sr_1_1?ie=UTF8&qid=1354447930&sr=8-1&keywords=mini+speakers
take it apart and connect it as shown here:
>> http://www.kobakant.at/DIY/?p=3794
this will amplify your mp3 player audio sufficiently to be heard through an embroidered fabric speaker.
hope this helps.
Ian01 says: Nov 30, 2012. 2:57 PM
This would be great on a running jacket or armband! I may try that sometime, and maybe even add a Bluetooth interface to connect to my phone.
ehudwill says: Nov 30, 2012. 2:36 PM
Fantastic job! Very creative! Thanks for sharing.
RningOnFumes says: Nov 30, 2012. 12:28 PM
I can definitely see a lot of applications with this. Awesome idea! Do you suppose if the diameter were larger, multiple magnets would work?
SelkeyMoonbeam says: Nov 30, 2012. 8:49 AM
This is awesome! You are an inspiration.
yoyology says: Nov 29, 2012. 6:00 PM
To solve the problem of needing to have the coils close, but not touching, could you work with a second non-conductive thread, spiraling both out from the center together, and couching over both at intervals?
Plusea (author) in reply to yoyologyNov 30, 2012. 4:44 AM
yes, this is a good idea that should work. i did something similar, but didn't make use of the isolation coil to make the conductive coil tighter/closer together. you could also at first stitch the conductive coil super close to itself and then go back over it with a non-conductive thread to isolate it using an embroidery stitch that completely covers it.
>> http://www.flickr.com/photos/plusea/8231428877/in/set-72157630984172386
Penolopy Bulnick says: Nov 29, 2012. 3:55 PM
Very cool! You should enter it into the A/V contest!
Plusea (author) in reply to Penolopy BulnickNov 30, 2012. 4:37 AM
thanks for the tip!
nickmccullough says: Nov 29, 2012. 3:48 PM
thats sooo sweet!
agm88 says: Nov 29, 2012. 12:17 PM
i can now put a speaker in my jacket and not worry about the bulkyness
snotty says: Nov 29, 2012. 11:06 AM
Very nice! Now someone make a hat or hoodie or soft headphones and post them here please.
randofo says: Nov 29, 2012. 7:40 AM
This is really cool. This is a great idea. You can do some awesome things with this.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
