My relative Ken was in need for a log splitter. I made one up for him, using a cheap bottle jack and various bits of stuff I already had lying around. The resulting splitter is foot operated and capable of splitting logs of various sizes.
Although this project falls in the category of Redneck projects, it is still important to think of safety. For example, I did not only look away when grinding steel, but I also squinted my eyes at the same time! *
Enjoy,
Richard Tegelbeckers
* Just kidding: WEAR GOGGLES!!!
Step 1: Main frame
For the main upright I used a section I salvaged from a store display unit. It has holes along it's length, which will be useful for adjustment purposes. I also used 25X50 rectangular box and 50x50 square box, which I recovered from other redundant fabrications. I did sketch up the main frame and sliding block before making them. After completion of the frame and the slider, I did not make use of any drawings and made it all up as I went along.
hubertnick2 says: Feb 6, 2013. 7:29 PM
would a 4lb diamond shaped wedge work on this?
RTegelbeckers (author) in reply to hubertnick2Feb 7, 2013. 4:19 PM
I have no first hand experience using such a wedge. However, I believe such a wedge would be made out of heat treated, high carbon steel. As such it could be a bit troublesome welding it. Not impossible, but it might be easier just welding a couple of plates into a wide wedge shape and grinding a sharp cutting edge onto it.
Botanikas says: Jan 18, 2013. 11:14 AM
after watching video only one thing comes to my mind: you need to protect your nuts when operating this splitter :D
RTegelbeckers (author) in reply to BotanikasJan 19, 2013. 12:35 AM
With small logs, having a cross section similar to the size of the wedge, the pieces will jump sideways. Larger sections tend to stay in place. Still, Ken will be wrapping a bungee around the logs, for the reason u pointed out...
Marco Maas says: Jan 11, 2013. 9:33 AM
Where are the times that men swearved with axes?
Nice job!
RTegelbeckers (author) in reply to Marco MaasJan 12, 2013. 11:29 AM
Step into the modern times... ;-)
Thanks Marco!
Vika84 says: Jan 11, 2013. 5:58 AM
Brilliant as usual! :-) Good luck in this contest!
RTegelbeckers (author) in reply to Vika84Jan 12, 2013. 11:28 AM
Thanks hun!!! :-D
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
