loading
Instructables tutorial for making a mini-gel electrophoresis system for DNA analysis. Gel electrophoresis systems are essential tools for any molecular biology research, but are often expensive to buy. The total cost of making this DIY system is around $50-$80, depending on where you source the laser cut acrylic parts.
Almost all of the assembly steps described in this tutorial require solvent welding the custom laser cut acrylic parts together using Weld-On #4, a fast-setting, clear, thin liquid cement. Weld-on is applied to the edge with a syringe applicator and drawn into the contact surfaces by capillary action. It is actually an easy and quick procedure, however, be sure to practice welding two scrap pieces of acrylic together if this a new technique to you.
The total length of time to complete assembly is 2-3 hours. Once complete, you will have the following parts:
- A UV-transmissive gel tray for casting a 7 x 7 cm mini-gel and comb;
- An electrophoresis chamber with lid.
Step 1: Parts and Tools
Acrylic materials and design files
From any supplier of acrylic materials (McMaster-Carr, US Plastics etc):
12” x 12” x 1/4" clear acrylic
12" x 12" x 1/4" blue acrylic (or preferred color)
5" x 5" x 1/8" clear acrylic
From McMaster-Carr:
6" x 6" x 1/16" teflon sheet , Cat # 8545K13
From Loop Acrylics:
1/8" solacryl (UV transmissive) - Optional : If you do not need a UV-transmissive gel tray then simply make these parts from regular clear acrylic.
Using the design files attached below, cut the parts from your material - the type of material to use is given in the title of the file. If you do not have access to a laser cutter, you can send the files to any laser cutting service (we use Pololu). These services will also carry most of the material you need with the exception of solacryl.You can also purchase a kit from our online store (IO Rodeo , Cat #IMG-01) for $93. The kit contains all of the laser cut parts and hardware, platinum wire (instead of stainless steel wire) and pre-assembled combs. You will still need to buy the Weld-On.
Hardware and tools
From McMaster-Carr:
2-56 Hand Tap Taper, Cat # 2522A663
Tap Wrench Sliding T-Handle, 0-1/4" (1.6-6.3mm) Tap Size, Cat # 2546A22
2x 2-56 Nylon Pan Head Slotted Machine Screw, 3/16" Length, Cat # 93135A076
4x 2-56 Nylon Pan Head Slotted Machine Screw, 1/8" Length, Cat # 93135A074
Stainless steel wire, 0.01" diam. Cat # 9882K31
2x 6/32 Hex machine nuts Cat # 91841A007
2x Flat Washer, No. 6 Screw Size, 5/16"Cat #  92141A008
From TAP Plastics:
IPS weld-on cement #3 or 4, Cat # 10792
Hypo-type solvent cement applicator, Cat # 25658
From Digi-Key:
2x Banana plug, Cat #655K-ND
Black banana plug cable, 36", Cat # 4771-36-0-ND
Red banana plug cable, 36", Cat # 4771-36-2-ND
4x Rubber feet , Cat # SJ5012-0-ND
Step 2: Comb Assembly
Follow the instructions in these two videos to complete the first step of assembling the gel comb.
Step 3: Gel Tray Assembly
Step 3A
Place the gel tray base flat on the benchtop. Take one of the gel tray sides and insert tabs into the slots at a right-angle with the tray base. Any paper covered sides should be facing OUT. Apply Weld-On to the joint and leave for 2-3 minutes. Position the second gel tray side in place. Before welding, make sure the 2 sides are in the same orientation i.e. with the notch for the combs lined up.
Materials: 2 x gel tray sides; 1 x solacryl gel tray base
Step 3B
Take the two gel tray wings and place paper-side down onto the benchtop. Take the part from Step 1 above and remove any remaining paper backing from the two sides. Place inverted onto the wings as shown in the image opposite so that the tabs and slots are lined up correctly and apply Weld-On to both joints.
Materials: Part from Step 3A; 2 x gel tray wings
Step 3C
Remove any remaining paper backing and insert combs to make sure everything fits correctly.
Step 4: Electrophoresis Tank Assemby
Step 4A
Take the tank base and remove the paper backing from one side. Lay the piece paper-side down on the tabletop. Place the two tank inner sides at a right angle on top of the base so that the edges are flush. Apply Weld-On along the joints.
Materials: 2 x tank inner sides; 1 x tank base
Step 4B
Place the Part assembled above onto the tank feet. Acrylic weld the joint between the two parts.
Materials: Part from Step 4A; 2 x tank feet;
Step 4C
Add the four electrode mounts (with screws) to the tank feet. Make sure that the mounts are in the correct orientation with the screws holes facing away from the center.
Materials: Part from Step 4B; 4 x electrode mounts
Step 4D
On one side, loop a piece of electrode wire over one of the screws. Stretch the wire and loop it over the second screw making sure that the electrode wire is kept straight. Clip the wire on one side while making sure that other side has excess wire (the excess wire will be looped over the banana plug). Repeat on the opposite side. Make sure that the pair of screws with excess wire are on the same side of the tank.
Materials: Part from Step 4C; electrode wire; wire clippers
Step 4E
Take the tank side with no holes and remove one side of paper backing. Lay the piece with paper side down flat on the benchtop. Lay the part from Step 4D side down so that the two wire ends are on the opposite side. Line up with the parts. Acrylic weld along the joints. Take the outer tank side with holes and repeat the process. Note that the wire end should now be on the same side as the holes as shown in the image opposite.
Materials: Part from Step 4D; 2 x colored tank sides (blue shown)
Step 4F
Fit one of the tank outer walls into the assembled part. The part should fit snugly. Weld along all 3 edges. Repeat for the opposite side.
Materials: Part from Step 4E; 2 x tank outer walls
Step 5: Electrode Assembly
Insert the two banana plugs into the holes on the side of the tank. On the inside of the tank, place a washer over the end of the banana plug. Loop the electrode wire 3-4 times over the plug. Finally place the nut on the end of the banana plug and tighten the nut to secure the wire in place. Clip any excess wire. Repeat the process at the second hole to make another electrode.
Materials: Assembled tank from previous step; 2 x banana plugs; 2 x washers; 2 x nuts; wire clippers
Step 6: Lid Assembly
Finally, gather the acrylic parts for making the lid. Remove the paper-backing from one side of all five pieces and weld along the edges to assemble the tank lid. Place the lid on the tank for the finished product !
Materials: 1 x lid base; 2 x lid side (long); 2 x lid side (short)
Step 7: Sample Gel
The sample gel shown in the uploaded image is a 1.2% agarose/TBE gel with SYBR-safe DNA gel stain (Invitrogen). Lanes contain a 1kb DNA ladder (Promega). Gel was electrophoresed at 100 V and viewed with our open source UV transilluminator. Imaging with a digital camera and Cokin A002 filter.
<p>I don't see any details here about how to make the comb itself or a laser file for it? The tapping part to attach the comb to the mount also seems a bit challenging, is there a way around it? Using a thicker piece of teflon perhaps?</p>
Can you speak a bit more about the electrodes you use (what are they made of, where you got them, what kind of cost, how long they last, etc.)?<br><br>Looking around, platinum seems exorbitantly expensive for even a 2&quot; length. I've successfully used carbon rods (i.e. artist graphite sticks) for (an admittedly ghetto) electrophoresis experiment, but these are only good for one to two uses before they break apart, often polluting the water when they do.<br><br>You chamber looks absolutely fantastic! I hope one day I'll be able to make something as professional looking!
The electrodes in the instructable above are stainless steel, which is a cheaper alternative and works well. The wire is listed in the materials above from McMaster-Carr (Stainless steel wire, 0.01&quot; diam. Cat # 9882K31). It works really well DIY kind of projects. Eventually you will have to replace it, although I haven't had to yet and I've used it maybe 10 times I think ? I made the electroced easy to replace by using screws which fasten the wire in place. All you need is a screwdriver to replace the wire. It is admittedly abit fiddly though.<br><br>For more regular use, such as in a lab, you should use platinum wire. Yes it is pricey. I get mine from a jewelry store in New York and include platinum wire electrodes in the electrophoresis kit we sell online (www.iorodeo.com - shameless plug !). Per electrophoresis kit you need 1 ft of platinum wire. The last time I bought the wire it cost $30.69 per ft, which is the cheapest I've found so far.
<p>where did you buy the platinum wire from? Could you give me the name of the place?</p>
<p>Hi Yuyumon, </p><p>We buy our platinum wire from a company called Myron-Toback (based in New York, NY). You can ask them for whatever length of platinum wire you need and they usually ship it pretty quickly (that day or next day). They do have a website but for ordering I would recommend calling them at <a rel="nofollow">212-398-8300</a> and asking to order platinum wire, part # PT010RSW. This is the 0.010&quot; round soft wire. Hope that helps.</p>
<p>Hi jorodeo,</p><p>Thanks for the quick response and the information<br>I really appreciate it :)<br></p>
Could you tell us more about your power supply?
The power supply I use, and shown pictured, is a Whatman Biometra Model 125 low voltage power supply that I bought last year from Labrepco for $50. The last time I looked on their website though they were not selling it anymore. I am hoping someone will come up with a cheap and open source low voltage power supply design soon.
Beautiful use of brainpower JoRodeo, well done!<br> Please, will someone post an <strong>instructable</strong> (<em>or links</em>) on using this? Experiments written for grade school, High School, or College level, but clearly explained in any case.<br> <br> Thanks Instructables Community!<br>
Congratulations for this instructable! The project is well illustrated and explained and the final object looks really professional.<br>I have crafted some electrophoresis chambers. However, without laser cutting, they looked &quot;home-made&quot;. Indeed, they worked very well. The only thing I bought from laboratory suppliers is the comb.<br><br>Based on my experience, platinum is a must for the electrode wire. Stainless steel works well at first but, over time, it can release electrolytic products that contaminate the electrophoresis buffer solution.
About This Instructable
56,562views
193favorites
License:
More by jorodeo:Gel electrophoresis power supply Blue LED transilluminator Educational colorimeter kit
Add instructable to:
