Hand Lights
Hand Lights
If you work with your hands and want to have more light where you're working, these hand lights (okay.. forearm lights) work great and are pretty simple to make. Use them for working with crafts, electronics, changing light bulbs, visiting the fuse box, rummaging through the crawl space, or cleaning out that one unlit closet.
I like to work on stuff in my living room, because that's where all the comfortable furniture and the good music system is. Unfortunately there's not a ton of light. I tried a task light but it got uncomfortably warm and cast harsh shadows. I tried the head mounted lamps like the cool DJ's wear, but I didn't like where I had to hold my head to see my work.
So I made these. They'll give you light right where you hands are, wherever you move them. Wearing one on both arms makes sure there's always enough light on everything, and they're pretty light and comfy. I've worn them for hours without noticing. And the little arms are adjustable so you can tweak where the light goes. Just be careful scratching your nose, they're bright enough they'll hurt if you look into them at close range.
I've been using them for carving and working on electronics. But I think it would be cool to make a couple with UV LEDs and break out the blacklight paint for DJing.
These instructions are for making one, but you'll probably want two.
Time: Less than an hour
Skills needed: Basic soldering, hot gluing, wire stripping etc.
Total cost: About $8-12, including the batteries.
Thanks!
I managed to be one of the winners in the Get the LED Outcontest! Thanks everyone for their support!
Parts:
  • 1 Battery holder for 3 AAA batteries.
  • 3 AAA batteries.
  • 1 mini toggle switch. (SPST. Skip this if your battery holder has a switch, or you just want to turn it off by taking the batteries out.)
  • 18 inches of 2 conductor stranded wire. 20 gauge or so.
  • 18 inches of Velcro. Hook or loop.
  • 1 inch of Velcro (the mate of the Velcro above)
  • 3 White LEDs: (I used 3, 7000mcd 3.5v, 25mA LEDs, though fewer, brighter LEDs would work too.)
  • 3 resistors, 47 ohm. (Or whatever your LEDs need. Check here.)
  • 18 inches of 9 or 11 1/2 gauge aluminum wire. AKA armature wire.
  • Solder
  • Hot glue
  • Electrical tape/heat shrink tubing.
Tools:
  • Soldering iron.
  • Hot glue gun.
  • Wire cutter/strippers.
  • Pliers.
  • Scissors.
Step 1Collect all your parts and tools.
To review:
Parts:
  • 3 AAA batteries.
  • Solder
  • Hot glue
Tools:
  • Soldering iron.
  • Hot glue gun.
  • Pliers.
  • Scissors.
60 comments
1-40 of 60next »
May 26, 2011. 8:41 PMScubaSteve says:
Reminds me of the goonies.
May 26, 2011. 5:58 AMphenoptix says:
Wow product of the day! Been a while since I've seen this project! There were some awesome entries for the particular "LED out" contest, good prizes too (especially the runner up prizes ;)) Was looking at the Monkeylectric website only yesterday, the video pro 7 is amazing.
Nov 4, 2010. 10:56 PMGIJane1968 says:
My 7 yr old son and I put together a pair of these. He loves them. Now he wants to make them for Christmas presents.
I am wondering if you could do this project with only 1 LED instead of 3? If so, what size LED and resister would you suggest? Would the power input be the same too?
Please keep in mind I am not an electronics geek type. But I am willing to learn.
Thanks!
Sep 28, 2010. 1:08 AMSergei- says:
mmmmmm so you have to constantly keep you arms in that position or move around the lights every couple of seconds
wouldn't it be more effective on your shirt or shoulder or any where like a head unit so you can freely move your arms around
even a torch in your mouth allows for better light
Sep 28, 2010. 8:04 PMSergei- says:
Hi
Thats my point you have to reajust for different angles but with something like head mounted you just look at it any way and don't need to adjust if not in the same possition
And somthing like shirt mounted will give you a better spread of light to cover the work area if it needs to be brighter just hold it closer and if it's to bright just a little further, and for both it just needs one set of lights not 2
Your idea is another way of looking at it anyway
and makes people think of other ways
keep up the experimenting
Sep 15, 2010. 12:04 PMgtsky303 says:
Great idea, similar to the HexLight shown on the tv show Pitchmen:
http://dsc.discovery.com/tv/pitchmen/inventions/inventions.html
Sep 20, 2010. 12:43 PMgtsky303 says:
I do remember them mentioning in that episode that there was at least one patent on a similar type of device and that they wouldn't be able to make the HexLights. But then they made a slight change to the design and the patent infringement no longer applied.
Sep 19, 2010. 9:03 AMWeaponMaker96 says:
I was just about to say that, but then i saw your comment.
Aug 3, 2009. 10:34 PMmenacel says:
is it ok if your battery compartment holds 4 AAA batteries? or can it only be 3?
Sep 20, 2010. 8:35 AMkadris3 says:
when only 4 cell holders are available, make a "dummy" battery. i have heard of using a dowel which is drilled down the middle. place copper disks on each end and solder a wire running through it. bits of old circuit board work well, as does cu flashing. that way u still need use only 3 batts and don't need larger resistors to throw away more power. 4.5 vdc(source) minus 3.4vdc(the led) divided by .02(20ma)=55 calculated ohms. for long term use go to the next highest fixed resistor.
'able a good idea. keep up the excellent work. unclecytheledguy.
Aug 4, 2009. 8:24 AMmenacel says:
cool thanks
Sep 20, 2010. 4:13 PMgabrielG2 says:
put your leds in series instead of in parallel.
2 leds in series creating a row, and 2 rows parallel with each other
Aug 26, 2009. 1:54 PMmiska_man says:
Where exactly can you get this armature wire? I'm finding it hard to buy in small amounts. Can I substitute some other type of wire instead? Thanks, Miksa
Sep 14, 2010. 4:19 PMsreyemhtes says:
Art supply stores. But you can also use heavy gauge copper wire -- like 10 gauge or lower -- any home center will have some. leave it insulated or strip it. Copper is pretty!
Sep 15, 2009. 5:03 AMcjanhero says:
excuse me can i ask what are the possible materials to replace the velcro
Aug 26, 2009. 5:26 PMmiska_man says:
Ok good, we have a Ben Franklin in town, so I don't have to wait on shipping from over the internet. How about the battery holder? Can I do a 4 AAA holder, or will that be too much voltage?
Jul 8, 2010. 3:06 PMphant0m_sp00f3ra says:
I love your project mate. And i'm working on a way to miniaturize the design, in order to be able to fit 2 of these to my Wayfarer glasses for night study, Project making, late trips to the fridge etc, perhaps using a smaller LED, and smaller batteries, what do you think?
May 5, 2010. 3:17 PMAdri3l says:
I think your idea is absolutely astonishing, but instead of using "plenty" of electrical tape, why not use heatshrinking tube; just a 3am thought :)
Jan 14, 2010. 1:50 PMknektek says:
instead of 47 ohms, i used ohms law to figure out that r should be 120 for
30 mA and 3.6v. nice idea! im going to make this with only 1 battery pack and a wire running down your arm and your other arm so you can have 2 sets for half the batteries! i had a thought that was wierd! run some wire from your power source through your underwear and next to your socks. that would feel wierd!
Dec 5, 2009. 5:21 PMnolte919 says:
Ask, and ye shall receive.
I did things a bit differently.  I used just one resistor for all thee LEDs instead of one per LED.  The LEDs I used, Digikey C503C-WAN-CBADA151-ND ($0.54), are a bit more focused than yours.  If I was to do it again, I might us more diffused ones.  I also put a nifty little pot, Digikey 3352W-101LF-ND ($1.24), in parallel with the resistor.  It was a 100 ohm resistor and a 100 ohm pot so the resistance can be varied between 0 and 50 ohms.  I thought this would let me conserve batteries if I so choose and crank up the current when the batteries start to die.  I also used a push button, Digikey 518PB-ND ($1.19), to turn it on and off.  For the main supporting wire I used the wire from marking flags.  The flags used to mark buried cables, Harbor Freight item number 95264 ($1.49 for 25).  Instead of running two wires up to the LEDs, I used the supporting wire as one connection.  So I soldered the three LED cathodes right to the supporting wire.  The wire, being galvanized, wasn't exactly conducive to soldering but with enough heat and solder it seems to be holding quite well.  I drilled a hole through the battery holder and ran the support wire through it where the support wire first meets the battery holder to add a bit of strain relief.  This way adjusting the support wire won't put quite so much strain on hot glue alone.  The battery holder part number was Digikey BC3AAW-ND ($1.22).  For the velcro straps I used Harbor Freight item number 66125 ($1.99).  These already had a plastic buckle on one end so I didn't need to used your spiffy trick of using the support wire to make one.  Because I wanted to keep both ends of the straps but they were way too long I took a section out of the middle.  I just cut some out of the middle and sewed it back together.  I used a razor blade to shave off some fuzz to make the seam smooth.  I also shaved off all the fuzz where I hot glued the battery holder to the strap.
I love my hand lights.
If you'd like to add any of this comment to the main part of your instructable please feel free and thanks for the great idea.
Aug 26, 2009. 6:58 PMmo5 says:
great concept. :)
Jul 15, 2009. 12:22 PMLeejin says:
Wow, I can really see this being useful for gaming at night. Typing on my Laptop has always been terrible. I've been looking for a way to light my keyboard effectively. Grats on the contest!!
Jul 17, 2009. 4:09 PMBridel568 says:
well at night you might want to use red LEDs so they don't mess up your vision. if you want to know what I mean go some place pitch black, wait till you can see without a light then turn on a flash light or something then turn it off. you wont be able to see for a while but with red light it wont mess up this vision.
Jul 8, 2009. 6:33 PMdombeef says:
Comgrats!
Jun 7, 2009. 6:51 PMPyroMonger says:
you should actually consider marketting this product...unless there already is such a thing around...I personally have never seen anything like it
Jun 8, 2009. 8:31 AMarirang777 says:
The item is great, but more than that is the concept behind. A very, very useful tool with tons of potential. Please, listen to the other members and try to market it, or at least patent it before a big-box-blood-sucker company does, stealing YOUR great idea. Instructables like this make me addict to it. I've faved it. Cheers!
Jun 9, 2009. 10:44 AMscoochmaroo says:
Right? I want to see that instructable too. I can't tell you how many times I've wanted to try something out like that, but not had the first clue how to do so.
Jun 24, 2009. 9:46 PMsmh says:
I'd buy two =)
Jun 7, 2009. 11:01 PMwupme says:
i second that. i would definately buy one of those.
1-40 of 60next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
176
Author:Grathio(Grathio Labs)
Creative swashbuckler. Writer for MAKE Magazine, presenter of inventions on TV, radio, magazines and newspapers. Professional problem solver. Annoyingly curious. Hacker of all things from computers ...
more »
