Helping Hands From Notebook Cooler Pad
Introduction: Helping Hands From Notebook Cooler Pad
This is my first instructable. And this instructable will show you how to build my version of the helping hands tool for soldering.
There are a lot of Helping Hands instructables out there. But for my version is just using notebook cooler pad that I'm not used anymore. It's quite easy to build and there is a LED to light up what you are trying to solder.
Ok, lets get started !!
Step 1: Parts and Tools
Here is all you will need:
- Cooler Pad for notebook
- Some wire that can bend into shape
- Jumper wire
- 4 alligator clips
- 1 LED white
- Resistor 330 Ohm
- PCB Matrix (Stripboard are recommended)
- 9 V battery
- 9 V battery holder with switch
- Shrink tubing
- Male header extended (optional)
- Blackhousing / female 1x1 header (optional)
- Soldering iron
- Solder
- Hot glue
- Mini drill
- Pliers
Step 2: How to Make an Arm
Step 1
Strip the end of the wire
Step 2
Bend the striped wire in the middle and back onto it self
Step 3
Put the wire in the slot of the alligator clips, and bend it around the striped end.
Step 4
Solder it in place for added strength and put on some shrink tubing (Optional).
Step 5
Make 4 of these.
Step 3: Make the Base With Cooler Pad
Step 1
disassemble the fan, to easier our work on the base.
Step 2
Make a hole with dremel (mini drill) for each side.
Step 3
Attach all wires to the hole.
Step 4
use the hot glue to attach the wire and make it stable.
Step 4: Build the LED and Reassemble the Fan
The circuit diagram was made with Fritzing, and the light rod is a led on a jumper wire.
Here are the materials needed for this step:
- 2 jumper wire
- 1 LED white
- soldering iron & solder
- shrink tubing
FOR THE CIRCUIT (optional)
- 2 Male Header (extended)
- 2 Blackhousing / Female 1x1
- shrink tubing
Step 1
Solder anode and cathode of LED with jumper wire and shrink tubing is essential to prevent shorting.
Twist the jumper wire, to make them rigid.
Step 2 (optional)
Soldering the wire (from the battery) with male header and use the shrink tubing.
Step 3 (optional)
Build the blackhousing / female header 1x1 that attach with the circuit we've been build before.
Solder components carefully to ensure there are no shorts, also ensure all connections are made at all points.
Step 5: Putting It All Together
Hope you enjoy my first instructable :)
Happy soldering !!
Greetings from Indonesia!!
    • Epilog Challenge 9
      Epilog Challenge 9
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
    Please where can i get the requirement including breathboard?
    thank you so much, I really appreciate it :)
    thanks for idea, really good instructable, i will make something like this but i will use cpu fan shield for base
    You are welcome, I'm glad you liked it. Be sure to post pictures of it when you are done :)
    here is mine, thank you again
    if this doesnt make good sense, then i dont know what does.
    Fume extraction + helping hands in one neat package...
    well played sir, well played
    wow, impressive inovasi tokcer gan.. terus berkarya !! (^_^)9
