Estimated Cost: ~$30-$50 (more if you don't already own the necessary tools)
Estimated completion time: 10-15 hours
Difficulty: Moderate but accessible to newcomers
_______________________________________________________________________
I have been making corsets for a few years now and I frequently receive emails from
people requesting tips and advice on how to get started. Also, I understand that depending
on their nature, corsets can be quite expensive and therefore not accessible to everyone.
I have spent considerable effort constructing a method for making a corset requiring the
least amount of technical knowledge, expensive tools and tedium I could manage. Even
so, there is still a lot of work involved. Please read the entire instructable before beginning.
If you have trouble seeing the details in any of the images click in on the little i in the top
left corner to view the image in its original format. Feel free to ask questions if something
is unclear or left out. The first image of each step is out of order so as to better illustrate
what that step entails in the thumbnails.
Also, please leave a comment with a photo of your finished work should you make your
own. I would love to see what people come up with!
UPDATE 8/11/2011: Corset pattern updated to include a better range of sizes and to allow for printing
on printers unable to print to the edge of 8x11 paper.
Remove these ads by
Signing UpStep 1Tools
Straight-stitch sewing machine or hand sewing materials (Not for the faint of heart!)
- For a sewing machine you will need a zipper foot
- Scissors
- Awl
- Marking tool (Preferably something non-permanent like a chalk pencil)
- Fray Check (If you use a brocade or similar fabric with a tendency to fray)
- Lighter or other heat source (An iron works but may deposit residue)
- Grommet Setter
- Pliers
- Ruler or seam gauge
- Dressmakers pins (Ones that won't snag on a sewing machine)
- Steam Iron
- Hole punch
- Pencil
- French Curve
Tools You Don't Need but May be Useful in Preserving Your Sanity:
Rotary Cutter
- Cutting Mat or other razor safe surface (office chair mats work great)
- Seam Ripper
- Weights (I make my own with bags full of steel shot)
I have never attempted it with real leather, but I suppose if the leather were thin enough it would work just fine. You might even be able you forgo the coutil layer. I wish I could be more help but I do not have much experience with leather working. Best of luck to you!
Petra wrote:
"Great instructable! Just a quick note for the person who asked if it could be done with real leather, it can, but you would need the coutil layer. Leather, especially soft, thin leather stretches like crazy and tears quite easy."
@Zanaji- I did a leather corset recently with a medium weight leather, a good viking sewing machine, and regular needles. It came out just fine. However, you will need a leather punch to make the grommet holes. Good luck!
1. Click the pattern link.
2. Click on file (top left)
3. Click download original and save it to your computer
4. Open it locally in the latest copy of Adobe reader
If you are still having trouble it is most likely that your printer software is doing something. When you go to print click on properties and browse through your printer options and see if there is another scaling feature enabled. Hope this helps.
If you run into any trouble with the new pattern feel free to PM me and I can give you more detailed help. My apologies for not accommodating all sizes initially. Best of luck!
If you could get your hands on an overbust that would be a different story. At some point in the far distance future I might make an overbust pattern but I just don't have the time for it right now. I recommend finding a custom corset seller on Etsy that will make you a bespoke overbust corset. Just make sure they use coutil fabric and steel bones. Message me is you want a recommendation.
Shoulder straps would help center the breasts over the front of the corset but I don't think it will give you what your are looking for.
I think you will be all right if you let your printer use it's shrink to fit function. A4 is only a touch narrow then Letter size but longer in length. As long as your match the corner marks correctly you should end up with a corset that is only marginally tighter then if you had printed it on Letter size paper.
But the thing i noticed is that the size it came out to be was the exact size of my body so i wasn't able to cinch. Although,. i did follow the size chart.
That aside. Your corset looks beautiful. Thanks for posting pictures.
Only Coutil and similar tightly woven strong, rigid materials should be used for corsets...that is unless you want to puncture your breast with the boning! :)
At the very least I would give them a few coats of Plastic Dip or other protective coating and a thorough washing before I would use them on fabric. I have seen sewing weights at some of the local shops that I would guess contain lead by their density, so I think as long as they're contained it is not an issue.
just wash it real well, cause there's likely other stuff on it... and probably rubber residue from the tires, road salt, road kill... dog poop that it hit and bounced off of... stick em in a tin can, melt the steel clips off, then pour the lead into non-stick(toxic fumes from teflon) muffin tins, don't use the can and tin for anything else.
It's common for people who specifically enter an instructable into a contest to talk about it so that people remember to vote if they appreciate the instructable. I've seen it in several of the other finalists for the Epilog challenge.
