Step 3The dangerous part...
Why should you do this? Because the CRT acts like a high voltage capacitor and it can hold a lethal charge. The charge stored in the CRT can last a very long time, usually a few months, sometimes for a few years...
So it is important to safely discharge the CRT before you do anything else - otherwise you might end up in the grave...
To discharge the CRT:
Connect one alligator connector clip to a flat-head screwdriver, and the other clip to another any screwdriver.
Push one screwdriver into the earth ground and take the other flat-head screwdriver and gently put the end under the suction-like cap. Keep pushing it in until you here a loud (or faint) "SNAP", the CRT is discharged, but push in the screw driver until you feel a little bump, the screwdriver had touched the metal clips Now the CRT is completely discharged.
Now, simply cut the HV wire off near the suction-like cap.
I took the suction-like cap off completely because I know how to do it. Taking the suction-like cap off the CRT can be tricky and dangerous.
If i discharge the tube, for safety reasons, as you described here, will it still work after putting it then in a differnt housing? I don't wanna break it.
The screwdrivers + alligator clip + wire are at ground voltage before touching the high voltage wire. When one of the screwdrivers touches the HV wire however, there will be a potential difference of +10-20kV across the screwdrivers + Alligator clip + wire with respect to the ground voltage. This will mean that a current will flow through them (a VERY high current). It's the current that will damage the screwdrivers, not the voltage. An increase in voltage will produce an increase the current.
