The earlier version involved cutting the nails and brazing the pieces back in place. I wanted to try an all-welded construction. The welds are all done from behind the finished surfaces, except for the weld in the center that is covered with brazing rod for decorative effect.
Click on this link to see the earlier version and to read about the significance of the Jerusalem cross.
Remove these ads by
Signing UpStep 1What you will need
I am using a flux-core wire feed welder, some holding jigs I made, some brazing rod with a MAPP gas torch, a wire wheel, and some spray shellac. I will also add a loop made from a small nut welded behind the nails and some bent wire for hanging on the wall.
I love working with metal, and these nails are brilliant.
