I have many used batteries around. Remote controls, cameras, many electronic gadgets all use batteries, mostly AA size. I always felt guilty for throwing away the used batteries. I know there are rechargeable batteries, but many electronics don't work well with rechargeables.
I also know that those "used" or "spent" batteries usually have some juice left in them. So to come up with a good use of used batteries, I've created a LED night light.
I like having a little night light on when I sleep. LEDs are perfect for this purpose, because they are energy efficient, and good at providing low intensity illumination.
This LED night light operates with just one battery. It utilizes a little circuit called Joule Thief to boost voltage out of an AA battery. I also added a light sensor to turn it on automatically when the surrounding is dark.
The circuit is energy efficient, and requires very low voltage to work. So it effectively sucks every bit of energy out of batteries. This type of circuit is often called "Joule Thief", because it works as though stealing every bit of energy (Joule is a unit for energy) out of battery.
I'm calling this project Night Joule Thief.
*The kit purchasing info can be found here: http://www.theledart.com/blog/night-joule-thief
Remove these ads by
Signing UpStep 1: Features
- Compact & streamlined design
- Uses only one AA battery (or any 1.5V battery you can hook up to)
- Easily adaptable to different size batteries - hook up holes to attach home made clips
- Two white LEDs
- Automatic turn on via a light sensor (adjustable sensitivity level)
- Energy efficient - works even with a run-down battery, down to 0.6V
- Choice of through-hole only components or SMD - mix & match on the same PCB
Visit Our Store »
Go Pro Today »
Also, that IC won't work with this project because it uses the solar panel as a light sensor...
Aki
I think I"ll buy a kit from ledartist!
Aki
Also, by definition, the original blocking oscillator circuit later given the Joule Thief name used only a single transistor. Your circuit is not a one transistor blocking oscillator and bears little resemblance to the original JT, so I don't believe it should use the same name.
Not only that, I'm rather biased with by the work of ledartist since I successfully used part of his circuit (diode and cap) to get my particular IC and inductor only "Joule Thief" to work with a flashing, multicoloured LED. Otherwise, I wasn't able to get this flashing LED to work with my circuit - see "Joule Thief" circuits, crude to modern...
I did mention that my version is a _variation_ of original, which I find very often on the net. I also think that showing different ways to achieve the same result can be inspirational.
I also contacted the person who named the circuit "Joule Thief" (Big Clive) and he did not have a problem with me using the name.
Aki
I'm sure it's easy for people who already has wire, etc. in hands, to make their own inductor. However even I (who tinker with electronics all my life) find purchasing the wire, and winding the coil to be cumbersome. So the reality is that most people will find it to be too much work.
Those who don't mind winding their own inductors most likely have already made their own Jule Thief.
I'm trying to get the widest audience to be interested in this (variation of) Joule Thief, so I designed the circuit to be as fool proof as possible.
Having said all that, I really think you should post your Joule Thief on Instructables. There are many people who want to know exactly how the circuit works, how to make the best inductor, etc.
Aki
The inductor is simply a nut and bolt. It works just as efficiently as a ferrite core and it's easy to find.
Thanks, Wayne.
Inductors don't have polarity par-se, but they indicate the polarity in terms of magnetic field. Only matters when you have two or more inductors sitting close together.
So if your unit is not working, please check other things, such as;
- polarity of LEDs
- correct transistors - Q1 and Q2/3 are different
- resistor values
- quality of solder joints (open or short to adjacent pads).
Did you look at this i'ble? http://www.instructables.com/id/Joule-Thief-LED-Night-Light-Kit-Step-by-Step/
Lastly, make sure to test your unit in a very dark place. Also test with the trimmer turn to the both extremes.
Good luck,
Aki
No need to change R3.
Aki
Hello!
Yes you can purchase the PCBs. Please see the pricing/details here:
http://www.instructables.com/community/Joule-Thief-LED-Night-Light-Kit-PCB/
Sounds good. Let me know when you are ready!
Aki
You can send personal message via profile page. I already sent you one, so you will get it.
Aki
Great! Thanks!
I just wanted to design the PCB to be as versatile as possible...
Aki
