3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Know Your IC: 555 Timers
Hello and welcome to a new instructables series called "Know Your Integrated Circuit"
Know Your IC seeks to demystify common Integrated Circuits and allows people to understand them to a point where they can use them in their own projects.
The first circuit in this series is the widely used 555 timer.
If you have suggestions for future chips we should cover, please shoot me an email!
UPDATE:
I decided to make the layout pictures easier to read, i know it was confusing some people. I hope this helps!
Step 1History Of The Chip
History Of The Chip
The 555 timer was created by Hans Camenzind (b. 1934) in 1970 while he was working for Signetics. The design process took about a year. Designing the chip was all done by hand, using rubylith which made the process take much longer than by today's standards.
The 555 timer replaced 23 transistors, 15 resistors and 2 diodes and allowed manufacturers to use this problem solving method much easier.
Today with billions of the chips in exsistence, it is one of the most widely used chips. Most people who do electronics hear of the 555 timer first. It is the gateway drug to the world of integrated circuits.
References
http://www.semiconductormuseum.com/Transistors/LectureHall/Camenzind/
48 comments
1-40 of 48next »
Nov 19, 2011. 7:50 AMjbaker22 says:
Can you show us about ne556n in another tutorial? It is like 555, but it is a dual timer.
Oct 29, 2011. 9:55 AMAmar143institute says:
cool i like it..........
Sep 5, 2011. 1:32 PMnodoubtman says:
Thanks a lot! :) i have got a blue light flashing after 6 hours rushing and working :`)
Have a great day! :)
Aug 7, 2011. 1:13 PMviper518 says:
Keep them coming. I love it!
Jul 26, 2011. 3:56 AMmakincoolstuff says:
howed you get the animations on?
Feb 1, 2011. 7:45 AMspikedeath69 says:
At radio shack there were two kinds of 555 timers and im not sure which to get also is the resistance of the resistor 1/4 watt or what? please reply thank you.
Feb 1, 2011. 8:06 AMspikedeath69 says:
what are the volts on this capacitor?
Jun 13, 2011. 3:06 PMSpudGunTechie says:
Resistors are measured in Ohms of resistance. Watts measure power, which will vary based on your circuit.
Similarly, Capacitors aren't really measured in volts, if that's what you're asking. Capacitors are measured in Farads. One would apply a current of some voltage to a capacitor to charge it, and expect it to produce a current as it discharges. Both are exponential functions of time, if you were wondering.
The author said that you'll need a 220 Ohm resistor, and a 100 Ohm resistor.
As far as capacitors, you'll want a 4.7 uF (that's micro Farads the 'u' should be a 'mue' character from Greek.).
It sounds like you sort of figured circuit analysis is just a matter of adding up a few numbers (once in a while it is), but usually its a bit more complicated than that.
I suggest reading about basic circuits. if you're still in school, take a physics class in electricity and magnetism. You'll be glad you did. You should be able to find some good tutorials floating around otherwise.
Jul 21, 2011. 10:10 AMcbates3 says:
Resistors are indeed measured in Ohms, but they are also measured in Watts to indicate how much power they can dissipate before they stop working. 1/4 watt resistors are one of the cheapest and most common, so I would suppose they would be sufficient.
Similarly, capacitors also have a voltage rating on them to indicate what the maximum voltage that the capacitor could hold a charge for. There are millions of different voltage values on capacitors, each made for a specific use. It is a good Idea to double the maximum voltage that you will be using in the circuit to get the proper voltage rating on your capacitors.
Jul 22, 2011. 12:11 PMSpudGunTechie says:
That's actually really good to know, thanks!
Jun 9, 2011. 12:10 AMSnappy83 says:
Thanks for the tutorial man! much appreciated! allways wondered what they ment by mono and astable. cheers!
May 25, 2011. 3:36 PMjunits15 says:
every time i tried to use a 555 to make a monostable multivibrator....i burned it out, went through 3 of them then gave up and made it with transistors.
May 18, 2011. 6:20 AMcircuit555 says:
in this diagram how would you wire 2 or more independent seperate flashing lights
thks
Mar 22, 2011. 3:10 AMnoobduino says:
will this work for the 555 timer http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&productId=761272&catalogId=10001&freeText=TLC555&app.products.maxperpage=15&storeId=10001&search_type=jamecoall&ddkey=http:StoreCatalogDrillDownView
Mar 16, 2011. 2:55 PM115494 says:
Hey I was wondering if you could show me how to make a monostable mode without the lights. Thanks.
Feb 28, 2011. 1:55 PMJeffery Mouse says:
I like this series! This is a great help to a novice like me!
Feb 13, 2011. 8:39 AMshubhneesh says:
bravo... i like it very much.
Jan 13, 2011. 1:21 PMprotostack says:
Great 555 astable calculator over here http://www.ohmslawcalculator.com/555_astable.php
Dec 26, 2010. 4:19 PMziga321 says:
have been searching for LED blinking all day and this is the first one that actually DOES work. Thanks-a-lot!
Nov 19, 2010. 1:40 AMwareneutron says:
that's i know
Nov 3, 2010. 12:45 AMlordxenosi says:
I would love to see more of these 'Know Your IC' instructables. I have little experience with common ICs and I found this simple tutorial to be educational and enjoyable.
Oct 28, 2010. 7:49 AMMatthewEnderle says:
Here is a better schematic
Oct 22, 2010. 4:13 AMfrikkie says:
I personally love the 555 chip there so many circuits one can build with it.
I build my first light effect with the same circuit as the author used.
Oct 19, 2010. 5:47 AMYOGESH YADAV says:
what are the adjustable timer circuit of 555.....???
Oct 11, 2010. 11:19 AMvince29 says:
i agree with xtank5, SW,and rabbitkillrun. there are a few incionsistancies between the text and the photos. When I first put it together the LED stayed on w/o blinking. In trying to correct this I m nable to get the LED lit again.
This could be the start of a very interesting development but answers should be forthcoming.
Oct 7, 2010. 10:16 PMwaldosan says:
i really like this series, it's opening my mind up to different ways you can use electronics.
Sep 29, 2010. 2:53 AMAbume4life says:
please i need a step-by-step guide on lm741 on bread board
Oct 7, 2010. 11:46 AMsuckafish says:
use google.....
Sep 29, 2010. 3:13 AMAbume4life says:
i have lm741 cant arrange the other component cause i dont have the circuit diagram
heeeeeeeeeeeeeeeeeelp
Sep 12, 2010. 2:58 PMxtank5 says:
I can't get it to work. All of my connections are good, they are just as you describe, but my LED just stays on. I've tried using larger caps to slow it down in case it was blinking faster than I could see, but even with 100uf it just stays on steady. Are you sure your plans work? Help would be nice.
Sep 9, 2010. 5:02 PMarhodes18 says:
I like this i'ble, but i wish there was just a little more explanation as to what the pins do. and yes i agree that the next should be LM386
Sep 13, 2010. 4:20 PMDream Dragon says:
Yes, I'd like to vote for an LM386 guide too.
Sep 10, 2010. 7:51 AMrabbitkillrun says:
I agree with this.
Sep 12, 2010. 6:53 PM8v92 says:
Good project! If you need equal on/off times a 74xx or 40xx counter can be used with the LM555 as long as Vcc is at 5 volts.
Sep 12, 2010. 10:54 AMphenoptix says:
Nice guide. It seems the consensus is the LM386 for the next IC. I've had a lot of requests regarding ZE002 IC chips or what seem to be the same in the ANA608 that are used in garden solar lights to give a Joule Thief style circuit. Not been able to source them and don't have the knowledge of ICs to work out what they are.
Sep 12, 2010. 2:32 AMwareneutron says:
i dont understand you work..
Sep 12, 2010. 2:31 AMwareneutron says:
what is this
Sep 11, 2010. 11:11 PMkevinhannan says:
I like this - a lot.
It's a great idea to have a 'series...' and I look forward to more.
I used to use the 555 and 556 way back in the early 80s and this 'ible has got me going to revisit those days with a few 555 projects.
I wouldn't mind reading a quality audio amp project with minimal components.
Sep 9, 2010. 3:54 PMsw says:
Seems like you're missing at least a connection in your diagram. Without a connection to V+ to charge up the capacitor, your circuit will be permanently stuck in the "On" position.
Also the choice of the 100k resistor at pin 7 means the Off time will be about 10 times the On-time. Perhaps a bit more about calculating exact component values to get precise frequencies will be helpful!
1-40 of 48next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
399
Author:frenzy
I'm the QA engineer here at instructables. I make cool projects in between testing instructables.com to make sure it works awesomely. Give me your bugs!
