If your microwave or other appliance has a built in light, chances are you have been wondering how to replace the anemic, inefficient bulb in it with a high power LED. Your time is at hand, as in this Instructable I will show you how to replace a 40W incandescent appliance bulb with a 3W white LED that will generate as much or more light at a >10X reduction in power consumption. Total project cost around $10. Fun, easy, cheap.
Remove these ads by
Signing UpStep 1Assemble your components
This project will require a handful of parts, pictured below. Your project may vary slightly depending on the bulb you are replacing, but the basic idea will be the same. The main components are the LED and the driver.
The driver is a cheap 120VAC to constant current unit built and sold direct from China. This is not a particularly safe, elegant, or reliable driver but the price is hard to beat. When working with electricity, especially 120VAC, be careful and do not take any chances.
The LED is a Cree XRE high efficiency warm white source, rated at 74 Lumens at 350mA.
List of Parts
Cree XRE Warm White LED http://ledsupply.com/creexre-ww.php
(You should get the XPG now, since it is more efficient and cheaper http://www.ledsupply.com/creexpg-ww105.php )
3W 120VAC LED Driver http://www.dealextreme.com/details.dx/sku.13552
Bulb to be replaced
Scrap of thin wood (plywood or popsicle stick)
Small section of aluminum channel for heatsink
Misc Wire
Misc epoxy (i.e. JB Weld)
I am currently connected to a thermo couple on the counter (room temp, not fridge) at 155 deg F. After 25 minutes.
Running long term at a junction temp of 130C will reduce the LED lifetime. How much, I don't know. 30%? In a fridge application I would say the LED will still outlive the fridge unless the door switch fails and the LED starts running around the clock.
As a rule of thumb (ha!) I'd say you should be able to touch the LED heatsink indefinitely without burning yourself for a good thermal design for long runtime. In an intermittent application like a fridge, you are probably fine.
-Jon
I am gonna order some more supplies, and try again, with an improved heatsink design.
In the meantime, I feel comfortable using these in the fridge. Awesome instruct able! Thanks for all the good advice.
I just built two of these, I took some liberties with the design, and actually doubled the LEDs per "replacement bulb" Still trying to understand all the LED terminology, and was hoping to build a couple more "bulbs" with the cool white emitters. here:
http://www.ledsupply.com/creexpg-w139.php
and am concerned that the original drivers would be appropriate for this different LED.
These are for my refrigerator and freezer, each replaces a 60 watt incandescent cool white bulb. I just couldn't stand having 120 watts of heater in my fridge, even if it's only on (in theory) when the door is open.
Input would be appreciated. I was also curious if there was a different driver I could/should use to drive two LEDs, as in my current design, I just used two drivers. The form factor of this was nice, but it's kind of "cheesy".
Thanks!
Having this in your fridge is a little bit concerning since you reach into the fridge with your bare hands and may contact the 120VAC wires. Make sure all the "hot" wires are covered and that the heat sink is isolated from 120VAC. Also be sure and use whatever bulb cover came with the fridge. I know some older fridges don't have a bulb cover, so if that is your case then I would be extremely careful. Additionally, the bulbs are certainly off when the door shuts. If not, all your food would spoil as your fridge ran flat out to try and keep cool. If you are worried about the theory of it, pull the shelves and the food out and climb inside and shut the door to find out. Good luck!
-Jon
Could a person use one of the "3 up" led stars with just one of these drivers?
http://www.ledsupply.com/creexpg-w354.php
The fridge is a bit of a mess actually. It's an LG french door model, one of the first ones (the new ones have LEDs from the factory) and there are well documented problems with the door switches failing, and the bulbs staying on. This results in the bulb housing actually melting, pictures have been seen on the internet of a stringy mess of melted plastic on top of food. LG has no real response except "changing the bulbs voids the warranty" SO that's the "why" for me with this project.
Details - I didn't like the "take the glass off of the lightbulb" although, if you had a non-standard lightbulb, that would be your best bet. Anyway, the base I used is actually one of those nifty things that you screw into a light socket, and make a "wall outlet" out of. SO, I just whittled out the plastic a bit, to expose the contacts, and soldered in the 110v leads. Then I filled that whole area with clear (non-electrically conductive) epoxy effictively insulating the 110v from the rest of the assembly. I ran the 110v leads up to my drivers, and then just wrapped the drivers with electrical tape. Further protection from the fridge user contacting 110V is afforded by the fact that there is in fact a clear plastic shroud over the "bulbs"
The installed look is awesome.
I don't understand completely the lumens that this is putting out, as the charts are a bit confusing (how many mA?) but I would say that these things are almost comparable to my O.E.M. 60 watt bulbs in this application.
-Jon
I gotta say that the light is a little..... harsh. Not quite as yellow (warm) as the incandescent). I was also surprised that the bulb takes a half second to turn on once the button is pressed. I wonder why.
Let's try this again!
If it is just the driver, you should be able to drop in another one ($2). I usually order them in packs of 10 since they are cheaper that way and nice to have around if they burn out.
Thanks for sharing your experience. As convenient as hot glue is, it isn't for every project.
Just to clarify, I am using it under the microwave in the same situation you did. There is no place for the heat to escape in that little glass and aluminum coffin.
Thanks again. It has been a fun project, and the results are fantastic!
LEDSupply.com is also now selling warm white Cree XP-G single LED star boards that are about 40% more efficient than the XR-E LED that I used. 105 Lumens at 350mA as compared to 74.
http://ledsupply.com/creexpg-ww105.php
I've noticed the start up lag as well. I attribute it to the time to charge the smoothing cap and the time needed for the current control loop to ramp up and stabilize.
Glad to see your successful bulb build. Let me know how it holds up. I've had no problems with mine, although it doesn't get used a whole lot.
-Jon
The price for XM-L's is also still pretty high as they are "cutting edge", almost 2x the XP-G. Do you know of a good source for XM-L's at a decent low quantity price?
Thanks for the tips.
-Jon
i'll see about testing it, i can hook a 9.6v rechargable battery up to it and the light turns on at almost the same brightness as if it was hooked up to the box, does this mean it probable produces 12vDC?
The LED replacement I detailed in the Instructable will not work as shown in your application. You will need a different drive circuit. See the link below for a suitable driver circuit:
http://www.dealextreme.com/details.dx/sku.13557
Long story short, you could run the LED right off the 12V but you'd need a power resistor, and the brightness and efficiency would be worse when compared to a constant current driver.
