3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LED Cube 4x4x4
Step 7The controller
The controller
  • last photo ←
The circuits controlling the led cube is described in the attached schematic image.
The RS-232 interface is optional. and can be omitted. That is IC2 and all the components connected to it. Future firmwares will enable PC communication..
Start by laying out all the components on you circuit board in a layout that enable all the components to connect with a minimal amount of wires. If everything fits, solder the circuit.
I won't give any more instructions on this, as the circuit probably will look very different from cube to cube, depending on the size of the circuit board etc..
Information on how to wire the cube to the controller circuit is in the next step.
61 comments
1-40 of 61next »
May 29, 2012. 12:03 PMjunaid amin says:
any one plz give me the code
Apr 15, 2012. 9:52 AMdjedje571 says:
HELLO,
What's the JP2 on the scheme please, i can't see on the picture?
Thanks
Mar 16, 2012. 3:18 PMavion-lou says:
plz can anyone give me the Schematic , i can't see anything from this one
Feb 29, 2012. 4:07 AMPrajith says:
hey guys wat is this JP2.... i dont understand its given in the schematic but nothngs mentioned about it else where....pls any1 help me....i am in the middle of this.....
Feb 25, 2012. 10:11 PMPrajith says:
hey is it possible to use an Atmega8 chip instead of atmega16.....
Feb 26, 2012. 9:53 AMajithmony says:
no dude...atmega16 got 20 pins and total of 40, and atmega8 got only 14 pins and total of 28..... u must get one atmega16..
Feb 26, 2012. 6:55 PMPrajith says:
So is there any way to get this program for PIC (16f877a) ........???
Feb 26, 2012. 9:52 AMajithmony says:
hey....wer is the 5v regulator in the part list????? and the 10 pin avr connector???? and the dp-9 connector????
Feb 23, 2012. 10:11 PMajithmony says:
please post the wiring diagram..the schematic is so confusing...!!!!
Feb 16, 2012. 5:05 AMcrth says:
im confused can someone please tell me what jp1 and jp3 are. does every point labled gnd link back to the ground and the same with +5v link back to the 5v power? if so whats the point in the capacitor in the bottom right corner please help me!!!
Feb 15, 2012. 9:42 AMchuckeaton says:
Does anyone know what the purpose of switch # 2 (S2) ? I have everything breadboarded and the cube is functional, but S2 doesn't seem to do anything.
Also I have omitted the circuitry for IC2 & IC3 as they were not necessary.
If anyone can help, I'd appreciate it greatly.
Also...check it out!
http://www.youtube.com/watch?v=OZ35wkChIos
Nov 8, 2010. 6:13 AMHardwyre says:
I can not find any 22pf capacitors, but I do have 33pf caps.. can I use those in place of the 22's?
Also, if anyone wants the schematics, I created some.
Schematic:
https://docs.google.com/leaf?id=0BzXyjatQnrrLNDlmZmNlYmMtY2MyNy00OWQ4LWIyNTItNzliYTJlMDFmYTMw&sort=name&layout=list&num=50
Board:
https://docs.google.com/leaf?id=0BzXyjatQnrrLYTJmZjVkZmUtOTg1Yy00NjkwLTliMTYtMTVjNTBmODFmMTQy&sort=name&layout=list&num=50
You'll also need the "con-dinkle" library for one of the connectors I used for the main power terminal.
A large zip file of libraries can be downloaded here (the con-dinkle library is under the 'connectors' sub folder):
https://github.com/niccodes/Eagle-Libraries
Apr 30, 2011. 5:40 PMHardwyre says:
Okay folks, for people having problems with the links, try these. They're TinyURL urls that should make it easier to copy and paste. As far as I can tell, the files are still alive on google docs and available to everyone.
Board: http://tinyurl.com/3gge58s
Schematic: http://tinyurl.com/3hs9vdl
And don't forget you'll also need the "con-dinkle" library for one of the connectors I used for the main power terminal.
A large zip file of libraries can be downloaded here (the con-dinkle library is under the 'connectors' sub folder): https://github.com/niccodes/Eagle-Libraries
Please remember that this is not my schematic and all commercial rights still belong to chr as far as I know. I don't believe he's have a problem with people selling one-offs, but I imagine production line copies are prohibited.
Feb 12, 2012. 9:45 PMajithmony says:
dude both pages dnt exist....!!!!
Nov 18, 2010. 8:31 AMrandyray says:
HI,
I can't seem to get to the schematic and board (assume it's Eagle).
Can you email me the files?
Thanks,
Randy Ray
vendor@randyray.com
Feb 12, 2012. 9:40 PMajithmony says:
u have given a regulator in the image and its not there in the part list.....????
Dec 26, 2011. 10:14 AMbrujita038 says:
What is JP1, JP2, S1 and S2 ? I'm confused with the diagram and the photo of the circuit
Dec 17, 2011. 1:04 PMbrujita038 says:
Can anybody tell me where are connected the transistors ? because in the simulation only say "To cube cathodes", but how ? In all cathodes or in the first LED of each floor .. Please explain me
Dec 14, 2011. 10:48 AMsteph1234 says:
do we need to do IC3 if we don t use 8-15v ?
Dec 14, 2011. 10:45 AMsteph1234 says:
hi
do we nedd to do IC3?or avr supplies the cube?
Oct 17, 2011. 9:40 PMcool55tcars says:
what is the blue jumper pin used for that is by the switch and ribbon cable connector???
Oct 18, 2011. 2:29 PMchempie says:
I think that it is an alternate power connector for the circuit. I think that you can use that or the 8-15V connector. The 8-15 power connector would probably be better as it will regulate the voltage on the board.
Aug 28, 2011. 11:30 AMbrainbeat2010 says:
Can someone help me, if I put the AVR into the socket i become a short circuit.
without avr the circuit is okay. What is wrong?
Aug 30, 2011. 11:17 AMbrainbeat2010 says:
problem solved pin 30+31 switched!
My Cube is running!
Is there an solution to run this cube with winamp plugin?
Jul 30, 2011. 1:04 PMshredape says:
What is the point of JP1 and JP3?
Jul 30, 2011. 2:13 PMshredape says:
And how are your powering the cube?
Jul 20, 2011. 1:47 AMhitesh_bahl says:
Can somebody please help me with the switching transistor used over here..?
Its product code.?
Thanks in advance...
May 27, 2011. 11:04 AMtemagaiva says:
hi guys, I do not speak English, but i understand you. I`m drawn 0 scheme in format 4x6.
Who wants to chat please contact ICQ 44370803, will be glad to communicate
Apr 20, 2011. 7:11 AMCaMoreno3 says:
JP3 isn't necessary, is it? Is it just an alternative to JP1 if I already have a 5V power supply? I can't really see any use for it.
Mar 29, 2011. 2:27 AMsaju says:
there is a program for winamp to conect? please tell me adress..
Mar 26, 2011. 6:10 AMfanqingguo says:
`ìô„ñ‡ý Âæ  ô-‡„ Ë YY ïåH""
ˆóf F Â eê-ý„1}You say English I don't understand!! Have will speak Chinese friends? Teach me, ok? thank you
I very want to learn, but do not look to understand! The fans from China.
Jan 25, 2011. 9:36 AMAfide says:
Man I want to build this so badly, but I don't get the circuit at all, it would be infinitely amazing if someone made a little video of creating it.
Oct 21, 2010. 5:29 PMHardwyre says:
Does anyone have the Eagle PCB file for this schematic? It would be greatly appreciated.
Sep 12, 2010. 4:23 PMsaulyx says:
hey guys, anyone actually have a diagram of this circuit that is clear? read all the comments and I cant find the one that MasterRed mentioned, and the one that CHR made is hard to read, anyone could help? Thanks!
Oct 4, 2010. 8:14 AMVoid Schism says:
hover over image and a box appears in the top left corner, click it and on the menu at the left select original size image
or as I am so kind, click here http://www.instructables.com/file/FMYFND2FEAHE8UU/?size=ORIGINAL
Apr 8, 2010. 12:06 PMrailrun says:
Hey
Cool project.
Actually I'm trying to build this for my girlfriend.
Can you upload the eagle-file of the circuit?
Aug 15, 2010. 8:14 PMmonkey99 says:
hy chr ;) it´s a very nice cube i like it !!!!!! i would the cube trying för my daughter but don´t understand the plan not who what where pins to what come .Can you help mi by this plan ? i where very very nice hopefull !!!!!!!!!!!!!! ;) sorry but my english is not better ihope do you understand me. When you can and would help me please send a email to me thank you !!!!!!!!!! Ahh i fogot the cube for my doughter must be in a plexiglass ok ................ here is my email hansifrank@inode.at
Jul 30, 2010. 4:43 PMrandomness72.5 says:
This may sound stupid but what is the ground connected to?
Jul 8, 2010. 1:21 PMmatrex says:
can be use atmega32l in LED Cube 4x4x4 help me Thanks.....
1-40 of 61next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
652
Author:chr
I like microcontrollers and LEDs :D
