3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LED Star Beam Clock
Step 2Drill Holes for LEDs
First off the hole positions need to marked. The clocks diameter was 9.25" so its circumference was about 29". Since I wanted 8 LEDs, I spaced the holes 3.65" apart. I cut a bendable piece of plastic to use as a ruler.
The Images below cover the following steps.
- Cover the area where the holes will be with some painters or masking tape.
- After testing for how far away from the wall I needed the LEDs, I found a notepad and pen that were the right height for the LEDs.
- Mark a line all the way around.
- Use a ruler to mark the spacing of the holes to be drilled on the line that was already drawn.
- Drill the holes, be careful and precise. I used a hand drill and it worked fine.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
63
Author:ChromationSystems(www.chromationsystems.com)
Designing electronic creations from microcontrollers, LEDs and anything else I can pull out of a dumpster and make use of. Check my Profile
