LACK SideTable mod by ChrysN
Featured
Step 2: Moding the table
The size of the opening on the table top was determined by the size of the plastic container I was planning to use as an insert.
  • With a measuring tape mark the centre point on the table.
  • Place the plastic container in the centre and mark around around it where to cut.
  • I have a shortage of decent power tools at home so to cut out the part of the table top I had to drill holes at the corners and used a hand saw to cut the rest (unfortunately leaving some rough and uneven edges).
  • *Once your remove the part of the table top, there is a cardboard honey comb that needs to be cut out as well.
  • Sand the edges smooth and check that the plastic container fits.
  • Assemble the legs of the table if you haven't done so already.
*Keep the top piece that you cut out, it can be used as the base for a mosaic inlay (see Step 7)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
