Introduction: Low Profile Monitor Mounts
these mounts are thin and have a low profile allowing for effective space management. The max weight is dependent on the the surface its attached to however it should be able to hold 30kg minimum this project can be scaled up or down for TV's or smaller screens.
Tools
-Hacksaw or angle grinder for cutting the plates
-Power drill or drill press for drilling holes
-A welder TIG/MIG/ARC (MIG recommended) alternatively each plate could be made from one piece removing the need for a welder
Materials
4mm mild steel sheet the width and height is dependent on the width between the monitors screw holes
4mm mild steel sheet approx 40mm by 100mm for the hooks
2-4 drywall/wood screws
2-4 machine screws that fit into your monitor usually come from the stand
(optional) plaster board wall plugs for attaching into plaster
All the steps are in my video : 1 Week Builds Ep-2 (Monitor mounts)
https://www.youtube.com/watch?v=WEE7Lgh23SE
