Introduction: Magnetic Clasp Repair
Picture of Magnetic Clasp Repair
This is the imitation leather case for my Kindle. It has a clasp with a button magnet buried in it. Eventually the magnet wears a hole in the fabric retainer on the underside of the clasp.
This Instructable will demonstrate using larger diameter shrink wrap tubing to cover the magnet and hold it in place while giving a neat, professional look.
Materials
  • Shrink wrap tubing - 1/2 inch size
Tools
  • Scissors
  • Heat gun or a hair dryer
Step 1: The Cloth Underside
Picture of The Cloth Underside
Next to my thumb is some of the soft cloth that retains the magnet used in the clasp. The actual magnet is below my thumb. (I completed this project before I thought about making an Instructable from it.)
Step 2: Two Materials
Picture of Two Materials
My wife volunteered to stitch what was left of the fabric around the magnet, but I saw that is extending the present problem into a later date in the future.
Initially I used some black duct tape I had bought as a repair material for a book binding. The duct tape worked and looked good at first. After a few weeks, though, the repeated pulls from the magnet during opening the case loosened the tape, and left unsightly gray adhesive from the tape.
I began to wonder about using shrink wrap tubing in place of the duct tape. But, most shrink wrap tubing comes in a relatively small diameter. At our local hardware store I found 1/2 inch and 1 inch diameter shrink wrap tubing in the drawers containing all sorts of odd parts.
Step 3: Cut to Length
Picture of Cut to Length
The 1/2 inch shrink wrap tubing is 1/2 inch in diameter when the tubing is rounded like a piece of pipe. But, it is 1 1/4 inches wide when flattened. The clasp on my Kindle case is 1 inch in width. The 1/2 inch diameter shrink wrap will work fine, and will wrap tightly around the clasp.
Slip the shrink wrap tubing over the clasp. Cut to length with a scissors.
Step 4: Shrink With a Heat Source
Picture of Shrink With a Heat Source
A heat gun is idea for shrinking larger diameter tubing like this. A hair dryer or a match would have worked, too.
(I did not actually do this over a nice table.)
Step 5: Finished
Picture of Finished
The shrink wrap tubing gives a nice clean look and should be very durable for a long time.
jumbleview (author)2016-03-17
Phil, I saw your comment to my post "Heat-shrink in Not for Insulation Only". Indeed your project is another one application of the heat-shrink tube. I intend to publish post in my private blog regarding heart-shrink non-traditional usage. Hope you will not object if I put there link to this your project.
Phil B (author)jumbleview2016-03-17
Thank you. Feel free to link it.
I was pleased to find odd sizes of heat shrink tubing in the small parts drawers at our local hardware store.
graydog111 (author)2015-01-23
Phil, look at < https://www.instructables.com/id/Color-Code-Keys/ > You can heat and stretch the Shrink Wrap Tubing to fit over something it would not normally fit over.
Phil B (author)graydog1112015-01-23
Thanks for the hint, Jack.
ChrysN (author)2015-01-18
Nice fix! I will keep this in mind, I have a phone case with a similar clasp which doesn't look very durable.
Phil B (author)ChrysN2015-01-18
Thank you, Chrys. I just looked on Amazon for shrink wrap tubing. Naturally, much of it is sized for electrical wires. There are some larger sizes, like 1/2 inch. Most of these come in assortments rather than single pieces. But, I paid about 1/3 the cost of an assortment for a single piece.
The hardware store I used to get my single piece is quite small. A larger store may have a larger selection of sizes to fit your phone case when the time comes. There is something to be said for checking the fit before you buy, even if you must pay more than you would like.
ChrysN (author)Phil B2015-01-18
Thanks, there is an electronics parts store in town which I know has shrink wrap tubing too.
About This Instructable
1,445views
4favorites
License:
Bio: I miss the days when magazines like Popular Mechanics had all sorts of DIY projects for making and repairing just about everything. I am enjoying ... More »
More by Phil B:Better Sound From Echo DotPicture or Shelf Hanging FixtureMake an Electric Motor Run Again
Add instructable to:
